[WARNING] Could not find ccd_width in file. Use --force-ccd
From @sellinios on Mon Oct 16 2017 19:13:52 GMT+0000 (UTC)
I have a phantom Pro 4 drone and I am getting the following message,
How do I set up the ccd manually ?
Could you please help me ?
Copied from original issue: https://github.com/OpenDroneMap/WebODM/issues/304
From @pierotofy on Wed Oct 18 2017 21:04:48 GMT+0000 (UTC)
Hi, if you know the value for your camera sensor, you can set it by modifying the default preset before submitting a task for processing:
My question is if you have an idea what is the number I should place for P4 pro
According to this site https://phantompilots.com/threads/size-camera-sensor-phantom-4.80008/ it’s 6.17.
Here I have found 13.2mm x 8.8mm, So I use 13.2 ?
Is it better if I left it without that info, or it works more efficient with that info ?
It shouldn’t make a big difference, so you can leave it out if you are not sure.
