I installed WebODM and ran a few 3D models. But I can’t figure out how to do volume measurements. Can anybody help?
Thank,
Jo
Thank,
Jo
Calculate your DSM and DTM as part of the processing and that should enable volume measurements.
I succeeded to do measure a building. It resulted in an area of 293 sq m and a volume of 158 cub m. This can’t be right. Any idea?
Maybe it would be better to share a screenshot, share a link to the results, or share the dataset. It may be that you’re using too narrow an area to measure, and so the volume is measuring just the roof cavity. Try to select the area just outside of the building on the ground.
