Volume Measurement Export Datum
@pierotofy @smathermather-cm When creating a volume measurement it works fine and exporting works fine, but it exports it as a geojason file. Any chance that there will be an update to export the file as a shapefile or dxf like how the contour export works.
Also exporting as a geojason makes the file not have any coordinate system. Any chance there will be an option to export the measurement file to have the coordinate system needed for a working file, just like the same way that the contour export works.
Thanks.
This could be an interesting feature to add; could you open a feature request on https://github.com/OpenDroneMap/WebODM/issues ?
@pierotofy What are the chances of this feature being added sooner rather then later?
I can’t speak for this feature in particular, but in general, the features that get implemented first are the ones that either have a fiscal sponsor or are implemented by a community member. :slight_smile: All other features happen as time allows.
@smathermather-cm What would the fiscal sponsor amount be to get this feature implemented?
Have you been able to export a volume dfx yet? or a free work around. It won’t export to other programs to check its calc’s. Not getting the best results
@Andrew volumes only export to geojson. You could try putting the geojson into QGIS to turn it into a dxf.
Thanks. I’m having issues with WEBODM calculating volumes. Its not correct by a pretty big margin. Using a P4P with and without GPC’s. Was hoping to send the processed info over to another program. Pix4d ran out:(
