Can the new WebODM windows native installers be virtualized on AppsAnywhere (see here)? My institution has tried and failed to virtualize WebODM via docker, so perhaps this new development under windows would help? this would open up WebODM as a teaching tool that students can use without having to install it themselves.
Yep, I’ll make the request and report back. Although if that fails, I assume I could get my University to buy the business installer and then just install it locally on all machines I need?
I use odm on a VMware server. Install: follow the instructions at the bottom of the github page for aws install. after you installed ubuntu on your vm server. Also change to the instruction on github Run sudo apt-get install python3-pip. Works with no issues and now can access from the web.
