View result from WEBODM Lightning
Hi all,
I have bought and successfully used the WEBODM Installer to process several maps. However my Macbook is running a bit slow on other task during processing of the data, so I tried WEBODM Lightning and bought some credits. I have processed a few datasets overnight and downloaded the results in an all.zip-file.
Perhaps I’m just dumb :open_mouth: but don’t now what to do with the resulting files. In WEBODM it was obvious but how do I view the result that I get from WEBODM Lightning???
Hey @chwi69 :hand: you can press the “Import” – “Import from URL” button from your local WebODM application and copy/paste the Lightning download url (ending with all.zip) to import the results in WebODM.
Otherwise you can also use QGIS (https://qgis.org), MeshLab (http://www.meshlab.net/) and CloudCompare (https://www.cloudcompare.org/) to simply extract the zip archive from Lightning and open the files individually.
Thank you - it works perfekt :slight_smile:
