I am having a strange problem with very small (44 × 336 pixels) orthomosaic being generated with WebODM 1.9.11 The source images were captured using my DGI Phantom 4 Pro v2 and are scaled to 2048 pixels on the long edge.
I have looked online and tried setting the following values:
Oof, yeah, that’s a nasty one! You’re kind of in uncharted waters in terms of reconstruction dimensions when your images lack EXIF, especially if you don’t add in GCPs to keep the reconstruction sane.
Glad you got it sorted!
Can we get a peek at the proper output? Looks like that survey came out nicely!
Hello, I am experiencing same problem before you sorted it out. Could you please inform how to check if our EXIF information is not corrupted or damaged.
I have import my geotagged photos to QGIS and confirmed that coordinates were ok, but when i import it into webODM, many photos were ignored so the results just a small area.
Thank you for your reply, I will try to obtain my last flight path. But as I can recall, i was flying automatically with about 5,5 m/s of speed and about 30 meter of height and that was a fly through.
In this case you probably suffer from rolling shutter.
The DJI has a Readout time for the sensor, so if you are low on height and high on speed, the sensor will have a shift in pixels. That will happen to nearly all cmos Sensors
Maurice gave you some great best-practices for mitigating survey/data collection issues!
In addition, you’re over a tight forest canopy and very close. You should significantly increase overlap/sidelap. It looks like something like 60% overlap/sidelap. That will not be sufficient, unfortunately.
Yes Saijin, you are right. I was using 65% overlap for that pass (it was my first mission, though).
Next time i will try with different configs as you guys suggested.
Flying higher can enhance feature detection and matching, and can also reduce the cost (airtime) of a survey. You often do not need leaf-level GSD for things like this, so a higher flight makes things much more simple.
Ok guys, thanks for your advices. Next time will surely try another configuration on that location. Meanwhile, on another field we were succesfully create orthophoto with ODM
[DJI Mavic Mini 1; Height at about 30 mtrs; Speed at 5,5 m/s; Overlap 75% for both sides]
You are right, but it will also increase the cm /px and therefore the resolution and it will not be good as. But the question is always: what’s the target of the mission?
