Hei, it’s been a while since I visited - but will be back more often over the next while
I just wanted to share possibly one of the most polar applications of OpenDroneMap yet - almost 82 degrees north, and also give a big thanks to everyone who has worked on the GPU-enabled ODM build, it has been working really well!
thanks snow works as long as the light helps bump up the texture. I think this was flown around 9 or 10 UTC in semi-overcast conditions - although at that latitude the sun is always low, so if the sun is out anytime is fly-able! This was a pretty messy flight, in 10-12 m/s wind and a bit of snow drift/saltation on the ground - the result is better than I had hope for!
