VERY large orthomosaics
Hi - I am processing some orthos utilizing a relatively small image count (50-150) that are resulting in very large output files at 1cm resolution (> 2gb tiff in some cases). Also I am enabling .png, however these are not being generated. Unfortunately for these cases I have been working with .jpegs that do not have gps metadata and I presume that may be related? Any thoughts / input / rationale would be greatly appreciated.
Depending on the area covered (how large is your area?) this seems normal?
The missing PNG is strange. Are you running the latest version?
Sorry for slow response. I have generally seen output files for similar image count and resolution in the sub-500mb range. I am using WebODM (manager 1.8.7)…thinking latest version. I’ve seen .png outputs from all other runs. Only differences I am aware of are the lack of metadata/gps and slightly lower resolution .jpgs for these new runs.
Could you copy/paste the task output from the task that’s missing the PNG? Perhaps there will be some clues there.
