Vertical skyline curving like dome
Hi. I’m new to WebODM. I created a model with about 200 images from as mavic pro with mostly default parameters. Everything seemed to go ok but the skyline goes up vertically and curves in the shape of a dome (see screenshot) Is this normal? Should I just fix it with post processing?
Or is there some setting I need to prevent this?
Thanks,
Mike
This can happen if you get a lot of shots of the sky. You have a couple of options: mask the sky in the photos before processing, or eliminate those photos from the process.
I should say – those two options or edit the mesh in post-processing.
Ah. Ok. Thank you for the quick reply. I will probably try all 3 of those separately just as a learning experience. Im very new to building models but am really having fun with it. Thanks again for the help!
Mike
