ValueErr
I am getting this error with odm and webodm I have also tried confirmed datasets it resizes the images then it says cannot process dataset
File "/code/run.py", line 15, in <module>
from opendm.utils import double_quote, get_processing_results_paths
File "/code/opendm/utils.py", line 3, in <module>
from opendm.photo import find_largest_photo_dim
File "/code/opendm/photo.py", line 18, in <module>
from opensfm.sensors import sensor_data
File "/code/SuperBuild/install/bin/opensfm/opensfm/sensors.py", line 4, in <module>
from opensfm import io
File "/code/SuperBuild/install/bin/opensfm/opensfm/io.py", line 14, in <module>
import rasterio
File "/usr/local/lib/python3.9/dist-packages/rasterio/__init__.py", line 22, in <module>
from rasterio._base import gdal_version
File "rasterio/_base.pyx", line 1, in init rasterio._base
File "rasterio/_shim.pyx", line 1, in init rasterio._shim
ValueError: numpy.ndarray size changed, may indicate binary incompatibility. Expected 96 from C header, got 88 from PyObject
Ive checked everything is up to date no idea…
Sorry for the trouble.
