Using WebODM with GPU
i am not sure about this and therefore want to ask:
If i installed webodm using Docker, and installed opendronemap/odm:gpu, can i use that GPU enabled odm with webodm? Or does webodm only run with its own odm?
And if so, how can i configure it?
When i run the odm:gpu Docker image, it exits, as it does not find images to process.
Basically i have the following Docker images pulled:
opendronemap/odm
opendronemap/nodeodm
opendronemap/webodm
When i run webodm through Docker, the following images are in use:
opendronemap/webodm_webapp
opendronemap/webodm_db
redis
Therefore i think that the odm and odm:gpu images are not used by webodm.
The goal is to run odm:gpu (with nodeodm?) on some servers using NVIDIA GPU cards and link them with clusterodm to expose the nodes to webodm.
it seems i figured out how to deal with webodm and GPU cards:
$ ./webodm.sh --gpu start
Warning: GPU support is not available for Windows
