Hi all,
Brand new to webodm - and to making 3d models from photos. I just purchased the windows installer and it seems to be running, so good so far
Is there a user manual that explains some of the options? I pretty much jumped into it and started a new project with 99 photos. Used all the default settings other then changing it to a 3d project. However, after about 20 minutes it came back saying unsupported tiff image. Seems kinda weird it would throw that error after 20 minutes since I assume it would have tried reading some of the images sooner. Any suggestions as to what I did wrong? Is it picky about the color space of the photos?
[INFO] Initializing ODM - Thu Apr 29 01:22:53 2021
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 28
[INFO] merge: all
[INFO] mesh_octree_depth: 12
[INFO] mesh_size: 300000
[INFO] min_num_features: 8000
[INFO] name: 2086827e-8812-4ac6-8432-a3e18aa873e2
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: high
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: True
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/images
[INFO] Loading 99 images
[INFO] Found 99 usable images
[INFO] Parsing SRS header: WGS84 UTM 16N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 5464px
[INFO] Photo dimensions for feature extraction: 2732px
[INFO] Not using the GPU
[INFO] [âuse_exif_size: noâ, âflann_algorithm: KDTREEâ, âfeature_process_size: 2732â, âfeature_min_frames: 8000â, âprocesses: 28â, âmatching_gps_neighbors: 8â, âmatching_gps_distance: 0â, âoptimize_camera_parameters: yesâ, âundistorted_image_format: tifâ, âbundle_outlier_filtering_type: AUTOâ, âalign_orientation_prior: verticalâ, âtriangulation_type: ROBUSTâ, âretriangulation_ratio: 2â, âfeature_type: SIFTâ, âuse_altitude_tag: yesâ, âalign_method: autoâ, âlocal_bundle_radius: 0â]
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm detect_features â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm match_features â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm create_tracks â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm reconstruct â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm compute_statistics --diagram_max_points 100000 â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_geocoords --reconstruction --proj â+proj=utm +zone=16 +datum=WGS84 +units=m +no_defs +type=crsâ --offset-x 704288.0 --offset-y 4734143.0 â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] Updating /var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/config.yaml
[INFO] undistorted_image_max_size: 1366
[INFO] Undistorting /var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm âŚ
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_visualsfm --points â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_openmvs â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfmâ
[INFO] Estimating depthmaps
[INFO] running /code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/openmvs/scene.mvsâ --resolution-level 0 --min-resolution 1366 --max-resolution 1366 --max-threads 28 --number-views-fuse 2 -w â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/openmvs/depthmapsâ -v 0
01:45:41 [App ] Build date: Apr 28 2021, 02:07:32
01:45:41 [App ] CPU: Intel(R) Core⢠i9-7940X CPU @ 3.10GHz (28 cores)
01:45:41 [App ] RAM: 24.83GB Physical Memory 7.00GB Virtual Memory
01:45:41 [App ] OS: Linux 5.4.72-microsoft-standard-WSL2 (x86_64)
01:45:41 [App ] SSE & AVX compatible CPU & OS detected
01:45:41 [App ] Command line: /var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/openmvs/scene.mvs --resolution-level 0 --min-resolution 1366 --max-resolution 1366 --max-threads 28 --number-views-fuse 2 -w /var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/openmvs/depthmaps -v 0
01:45:41 [IO ] error: unsupported TIFF image
01:45:41 [App ] error: failed loading image header
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0719.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0711.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0678.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0726.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0725.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0741.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0686.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0672.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0681.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0666.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0676.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0694.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0680.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0714.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0747.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0713.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0667.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0699.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0755.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0759.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0683.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0701.tif.tifâ
01:45:41 [App ] error: failed reloading image â/var/www/data/2086827e-8812-4ac6-8432-a3e18aa873e2/opensfm/undistorted/images/DJI_0668.tif.tifâ
01:45:41 [App ] error: preparing images for dense reconstruction failed (errors loading images)
Child returned 1
===== Done, human-readable information to follow⌠=====
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips â OpenDroneMap 2.4.7 documentation
File â/code/stages/odm_app.pyâ, line 83, in execute
File â/code/opendm/types.pyâ, line 338, in run
File â/code/opendm/types.pyâ, line 319, in run
File â/code/stages/openmvs.pyâ, line 77, in process
system.run(â%s â%sâ %sâ % (context.omvs_densify_path,
File â/code/opendm/system.pyâ, line 82, in run
raise SubprocessException(âChild returned {}â.format(retcode), retcode)
