I am processing 100 photos (without a GCP) and haven’t had issues before but now I am receiving this error message repeatedly after 6 seconds of processing
Error: Directory (Last IFD item) with 19712 entries considered invalid; not read.
Error: Directory (Last IFD item) with 1792 entries considered invalid; not read.
[WARNING] Could not generate coordinates file. Ignore if there is a GCP file. Error: Error in OdmExtractUtm:
DJI_0425_2.JPG: No Exif data found in the file
For more detailed information, see log file.
[ERROR] Could not find file /var/www/data/607d0ebe-df57-427d-9d55-1fc520bbe05b/odm_georeferencing/coords.txt
plasm.execute(niter=1)
File “/code/scripts/dataset.py”, line 116, in process
f.write(outputs.reconstruction.projection.srs)
AttributeError: ‘NoneType’ object has no attribute ‘srs’
task output:
[INFO] Fast orthophoto is turned on, automatically setting --use-25dmesh
[INFO] Initializing OpenDroneMap app - Tue Apr 17 19:14:31 2018
[DEBUG] Loading dataset from: /var/www/data/607d0ebe-df57-427d-9d55-1fc520bbe05b/images
[DEBUG] /var/www/data/607d0ebe-df57-427d-9d55-1fc520bbe05b/images
[DEBUG] Loaded DJI_0389.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143744722 | lon: -71.0482009445 | alt: 66.422
[DEBUG] Loaded DJI_0381.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141338333 | lon: -71.0486957222 | alt: 66.522
[DEBUG] Loaded DJI_0391.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143699723 | lon: -71.0484798333 | alt: 66.322
[DEBUG] Loaded DJI_0360.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141334167 | lon: -71.0521699167 | alt: 66.622[DEBUG] Loaded DJI_0360.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141334167 | lon: -71.0521699167 | alt: 66.622
[DEBUG] Loaded DJI_0425_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0364.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141335277 | lon: -71.0515651945 | alt: 66.522
[DEBUG] Loaded DJI_0417.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099400556 | lon: -71.0523305556 | alt: 66.184
[DEBUG] Loaded DJI_0339.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141488889 | lon: -71.0556366389 | alt: 66.822
[DEBUG] Loaded DJI_0345.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141335556 | lon: -71.05468525 | alt: 66.822
[DEBUG] Loaded DJI_0377.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141361666 | lon: -71.0493568333 | alt: 66.522
[DEBUG] Loaded DJI_0367.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141329722 | lon: -71.0510618889 | alt: 66.422
[DEBUG] Loaded DJI_0344.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141346944 | lon: -71.0548496945 | alt: 66.822
[DEBUG] Loaded DJI_0351.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141344721 | lon: -71.0536910278 | alt: 66.722
[DEBUG] Loaded DJI_0424_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0408.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143709167 | lon: -71.0511218333 | alt: 66.122
[DEBUG] Loaded DJI_0388.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143784444 | lon: -71.0481735833 | alt: 66.422
[DEBUG] Loaded DJI_0417_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0340.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141391389 | lon: -71.0555121389 | alt: 66.722
[DEBUG] Loaded DJI_0372.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141343888 | lon: -71.0502090278 | alt: 66.622
[DEBUG] Loaded DJI_0420.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099417778 | lon: -71.0519653889 | alt: 66.384
[DEBUG] Loaded DJI_0352.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141345001 | lon: -71.0535249444 | alt: 66.622
[DEBUG] Loaded DJI_0422_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0420_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0425.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099368889 | lon: -71.0511429722 | alt: 66.784
[DEBUG] Loaded DJI_0399.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143716111 | lon: -71.0496748612 | alt: 66.122
[DEBUG] Loaded DJI_0396.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143731667 | lon: -71.0491937222 | alt: 66.122
[DEBUG] Loaded DJI_0418.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099440833 | lon: -71.0522792222 | alt: 66.284
[DEBUG] Loaded DJI_0410.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143704722 | lon: -71.0514815278 | alt: 66.022
[DEBUG] Loaded DJI_0383.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141348055 | lon: -71.0483640556 | alt: 66.622
[DEBUG] Loaded DJI_0426.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099371944 | lon: -71.0509776944 | alt: 66.784
[DEBUG] Loaded DJI_0386.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141791667 | lon: -71.0481225554 | alt: 66.522
[DEBUG] Loaded DJI_0394.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143726944 | lon: -71.0489534445 | alt: 66.022
[DEBUG] Loaded DJI_0358.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141334167 | lon: -71.0525081389 | alt: 66.622
[DEBUG] Loaded DJI_0354.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514134 | lon: -71.0531921667 | alt: 66.622
[DEBUG] Loaded DJI_0422.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099385277 | lon: -71.0516396944 | alt: 66.584
[DEBUG] Loaded DJI_0397.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143727778 | lon: -71.0493491388 | alt: 66.122
[DEBUG] Loaded DJI_0419_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0393.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514372139 | lon: -71.0487198611 | alt: 66.222
[DEBUG] Loaded DJI_0414.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.51437225 | lon: -71.0521341389 | alt: 66.322
[DEBUG] Loaded DJI_0403.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143708611 | lon: -71.05035825 | alt: 66.022
[DEBUG] Loaded DJI_0407.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143719166 | lon: -71.0509416667 | alt: 66.122
[DEBUG] Loaded DJI_0366.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141321945 | lon: -71.0512275278 | alt: 66.422
[DEBUG] Loaded DJI_0401.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514372 | lon: -71.0500289167 | alt: 66.122
[DEBUG] Loaded DJI_0411.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514371361 | lon: -71.0516575556 | alt: 66.222
[DEBUG] Loaded DJI_0412.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143732778 | lon: -71.0518185833 | alt: 66.122
[DEBUG] Loaded DJI_0349.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141339166 | lon: -71.0540233333 | alt: 66.722
[DEBUG] Loaded DJI_0398.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514371139 | lon: -71.0495147779 | alt: 66.022
[DEBUG] Loaded DJI_0363.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.51413325 | lon: -71.0517384722 | alt: 66.522
[DEBUG] Loaded DJI_0368.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141338889 | lon: -71.0508878611 | alt: 66.422
[DEBUG] Loaded DJI_0348.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141334722 | lon: -71.054189 | alt: 66.722
[DEBUG] Loaded DJI_0427.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099367222 | lon: -71.0508135278 | alt: 66.784
[DEBUG] Loaded DJI_0405.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143716667 | lon: -71.0506856944 | alt: 66.122
[DEBUG] Loaded DJI_0373.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141350834 | lon: -71.0500179167 | alt: 66.522
[DEBUG] Loaded DJI_0400.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143719722 | lon: -71.04984825 | alt: 66.022
[DEBUG] Loaded DJI_0361.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.51413375 | lon: -71.0520039167 | alt: 66.622
[DEBUG] Loaded DJI_0350.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141348611 | lon: -71.0538571667 | alt: 66.722
[DEBUG] Loaded DJI_0404.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143708333 | lon: -71.0505265278 | alt: 65.922
[DEBUG] Loaded DJI_0423.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099369167 | lon: -71.0514749722 | alt: 66.684
[DEBUG] Loaded DJI_0378.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141367779 | lon: -71.0491905276 | alt: 66.522
[DEBUG] Loaded DJI_0418_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0427_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0369.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141335556 | lon: -71.0507225278 | alt: 66.422
[DEBUG] Loaded DJI_0423_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0342.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514135 | lon: -71.0551815556 | alt: 66.822
[DEBUG] Loaded DJI_0426_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0362.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141339166 | lon: -71.0519123889 | alt: 66.522
[DEBUG] Loaded DJI_0357.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141338889 | lon: -71.0526718889 | alt: 66.722
[DEBUG] Loaded DJI_0409.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143700833 | lon: -71.0513111389 | alt: 66.122
[DEBUG] Loaded DJI_0380.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141336945 | lon: -71.04886175 | alt: 66.422
[DEBUG] Loaded DJI_0384.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141353612 | lon: -71.0481980835 | alt: 66.522
[DEBUG] Loaded DJI_0343.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141348889 | lon: -71.0550170555 | alt: 66.922
[DEBUG] Loaded DJI_0390.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143732778 | lon: -71.0483285556 | alt: 66.422
[DEBUG] Loaded DJI_0346.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141325833 | lon: -71.0545206111 | alt: 66.822
[DEBUG] Loaded DJI_0402.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143714167 | lon: -71.0501888889 | alt: 66.022
[DEBUG] Loaded DJI_0375.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141363332 | lon: -71.0496857778 | alt: 66.522
[DEBUG] Loaded DJI_0413.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143737778 | lon: -71.0519760556 | alt: 66.322
[DEBUG] Loaded DJI_0387.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5142902222 | lon: -71.0481510556 | alt: 66.422
[DEBUG] Loaded DJI_0419.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099424167 | lon: -71.0521259444 | alt: 66.284
[DEBUG] Loaded DJI_0370.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141330278 | lon: -71.0505488333 | alt: 66.522
[DEBUG] Loaded DJI_0376.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141366945 | lon: -71.0495204444 | alt: 66.422
[DEBUG] Loaded DJI_0424.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099366944 | lon: -71.0513093889 | alt: 66.784
[DEBUG] Loaded DJI_0374.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141355556 | lon: -71.0498520833 | alt: 66.422
[DEBUG] Loaded DJI_0359.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514133 | lon: -71.0523349444 | alt: 66.622
[DEBUG] Loaded DJI_0421.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5099403611 | lon: -71.0518037222 | alt: 66.584
[DEBUG] Loaded DJI_0379.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514136 | lon: -71.049025889 | alt: 66.422
[DEBUG] Loaded DJI_0341.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141365 | lon: -71.055346 | alt: 66.822
[DEBUG] Loaded DJI_0355.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141347222 | lon: -71.053019 | alt: 66.722
[DEBUG] Loaded DJI_0421_2.JPG | camera: | dimensions: 2048 x 1536 | focal: None | ccd: 5.75 | lat: None | lon: None | alt: None
[DEBUG] Loaded DJI_0356.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141345001 | lon: -71.0528368889 | alt: 66.622
[DEBUG] Loaded DJI_0382.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141343056 | lon: -71.048529361 | alt: 66.622
[DEBUG] Loaded DJI_0416.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143730277 | lon: -71.0524531944 | alt: 66.222
[DEBUG] Loaded DJI_0347.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141327778 | lon: -71.0543543056 | alt: 66.822
[DEBUG] Loaded DJI_0395.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514372611 | lon: -71.0490299722 | alt: 66.122
[DEBUG] Loaded DJI_0365.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141333055 | lon: -71.0513915833 | alt: 66.422
[DEBUG] Loaded DJI_0392.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143706388 | lon: -71.0485572501 | alt: 66.222
[DEBUG] Loaded DJI_0353.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141346944 | lon: -71.0533586945 | alt: 66.722
[DEBUG] Loaded DJI_0385.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514134361 | lon: -71.0481033889 | alt: 66.722[DEBUG] Loaded DJI_0385.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.514134361 | lon: -71.0481033889 | alt: 66.722
[DEBUG] Loaded DJI_0415.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143741111 | lon: -71.0522956667 | alt: 66.222
[DEBUG] Loaded DJI_0371.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5141332777 | lon: -71.050384 | alt: 66.522
[DEBUG] Loaded DJI_0406.JPG | camera: dji fc300x | dimensions: 2048 x 1536 | focal: 3.6 | ccd: 6.2 | lat: 41.5143725 | lon: -71.0508533333 | alt: 66.122
[INFO] Found 100 usable images
