Unfamiliar output during "Scanning input" step
I’m running a large dataset on High Resolution settings and noticing it output the following -
Found point cloud: odm_georeferencing/odm_georeferenced_model.laz
Scanning input
1/1: odm_georeferencing/odm_georeferenced_model.laz
00:40 - 4% - 14,696,448 - 1,322(1,120)M/h - 67W - 19R - 281A
01:00 - 5% - 18,522,112 - 1,111(920)M/h - 112W - 26R - 312A
01:20 - 6% - 21,835,776 - 982(663)M/h - 120W - 44R - 346A
I recognize the Scanning input and 1/1: odm_georeferencing/odm_georeferenced_model.laz but I’ve never seen the lines under it. Does anyone know what it’s doing? Is it normal? This is a 664 image dataset running on High Resolution on a machine with 64 gb ram.
Thanks!
That’s normal. That is the process of preparing the point cloud for viewing in the browser. You might only notice that on larger datasets as it will take longer.
Ok good to know. Thanks
