Unexpected EOF
Howdy guys!
Windows 10 Pro on a lenovo M series Thinkcentre 16 GB ram 500 GB SSD
Virtualization ON
I tried installing everything for free, but got over my head quick, even with instructions and youtube,
So I bought the installer, everything including WebODM installed and I got to the "Downloanding 2gb, go get some coffee. I cant get past that It fails everytime, and i have no idea why. I tried searching and found nothing.
Here is the report from the Console Tab.
                       [03]: Hyper-V Virtual Ethernet Adapter
                       [04]: Hyper-V Virtual Ethernet Adapter
                       [05]: Hyper-V Virtual Ethernet Adapter
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Detected Windows 10 with Hyper-V support
Initializing console…
Checking if current user is in docker-users group
User is in docker-users group
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Client: Docker Engine - Community
Version: 18.09.2
API version: 1.39
Go version: go1.10.8
Git commit: 6247962
Built: Sun Feb 10 04:12:31 2019
OS/Arch: windows/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 18.09.2
API version: 1.39 (minimum version 1.12)
Go version: go1.10.6
Git commit: 6247962
Built: Sun Feb 10 04:13:06 2019
OS/Arch: linux/amd64
Experimental: false
Press Start WebODM to launch
Checking for MS Edge Zone…
Zones are OK
C:\WebODM Manager>cd WebODM/
C:\WebODM Manager\WebODM>docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
Starting broker …
Starting db …
Starting worker …
Starting node-odm-1 …
Starting webapp …
e[5Ae[2K
Starting broker … e[32mdonee[0m
e[5Be[4Ae[2K
Starting db … e[32mdonee[0m
e[4Be[2Ae[2K
Starting node-odm-1 … e[32mdonee[0m
e[2Be[3Ae[2K
Starting worker … e[32mdonee[0m
e[3Be[1Ae[2K
Starting webapp … e[32mdonee[0m
e[1BNo containers to start
Pulling db (opendronemap/webodm_db:)…
latest: Pulling from opendronemap/webodm_db
Pulling node-odm-1 (opendronemap/nodeodm:)…
latest: Pulling from opendronemap/nodeodm
unexpected EOF
C:\WebODM Manager\WebODM>exit 1
Error: docker-compose exited with code: 1
PLEASE HELP! Thanks!
Hey @Jake_Clemons :hand:, thanks for supporting the project.
Are you connected to a reliable internet connection? I’ve seen that problem before when the connection was from a mobile hotspot, or a spotty connection. Also, if you are connecting from a corporate environment it’s possible that a firewall might be interfering with the download.
Thanks for the reply.
YES mobile hotspot, I guess I can take the entire machine to somewhere that has better internet. im downloading at 800kbps to 3mbps.
I have disable all firewalls and protection to get it started up.
Once everything gets set up, I wont have issues with the slow internet will I?
Correct, once everything is setup you can even work entirely offline!
I took my computer to a better internet source and got everything downloaded, it took some work but i got Webodm to start. And even made maps, I had to restart my computer and now getting this error.
As well as a popup about network connectivity.
06db261f568b redis “docker-entrypoint.s…” 3 hours ago Up 2 minutes 6379/tcp broker
Version: 18.09.2
API version: 1.39
Git commit: 6247962
Experimental: false
Engine:
Version: 18.09.2
Git commit: 6247962
Experimental: false
Zones are OK
Starting broker …
Starting db …
Starting worker …
Starting webapp …
e[5Ae[2K
e[5Be[4Ae[2K
Starting node-odm-1 … e[31merrore[0m
e[4Be[1Ae[2K
Starting webapp … e[31merrore[0m
e[1Be[3Ae[2K
Starting db … e[31merrore[0m
e[3Be[2Ae[2K
Starting worker … e[31merrore[0m
e[2B
ERROR: for node-odm-1 Cannot start service node-odm-1: driver failed programming external connectivity on endpoint node-odm-1 (2f6351f4187d4872a161fdc0b4d5e1adf39b061428e6d96c7495f8861fc8e20f): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:33027:tcp:172.23.0.2:3000: input/output error
C:\WebODM Manager\WebODM>exit 0
If you cannot access WebODM within 5 minutes, press Update. You can close this window now.
ERROR: for db Cannot start service db: driver failed programming external connectivity on endpoint db (91a277594a616713796a33e294d89b0ae75e198087b232cef379bc14f911e5f0): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:33029:tcp:172.23.0.3:5432: input/output error
Stopping broker …
e[1Ae[2K
Stopping broker … e[32mdonee[0m
e[1B
Starting db …
Starting broker …
Starting worker …
Starting webapp …
e[3Ae[2K
e[3Be[5Ae[2K
e[5Be[1Ae[2K
e[1Be[4Ae[2K
e[4Be[2Ae[2K
e[2B
ERROR: for node-odm-1 Cannot start service node-odm-1: driver failed programming external connectivity on endpoint node-odm-1 (b31da2d07a89c6750127e456695b0d4848aecc9e1b85a46976c564b77e48004f): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:33047:tcp:172.23.0.2:3000: input/output error
ERROR: for db Cannot start service db: driver failed programming external connectivity on endpoint db (628db0e9d16ebcee81768efe38e6f840403ded26dbc22d7d5d24334c6d2a53df): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:33049:tcp:172.23.0.3:5432: input/output error
Could you try to “disable the experimental features” as well as restarting docker for windows, then restarting WebODM Manager?
From the task tray, right click the “white whale icon” then press “Settings” then go to “Daemon” and make sure the box is unchecked:
Then press Apply. To restart docker right click the same icon from the task tray and press “Restart…”
Relevant thread: https://github.com/docker/for-win/issues/573
