Understanding Project Path and Dataset Path From Command
I have my nodes, cluster, and images all waiting to go (thank you all); however, I am still one command away from distributing to then processing my images on my machines.
I am stuck here:
docker run -ti --rm -v /my/project:/datasets/code opendronemap/odm --project-path /datasets --split 800 --split-overlap 100 --sm-cluster http://<cluster-odm-ip>:3001
Particularly the /my/project:; /datasets/code; –project-path /datasets bits.
How can I get ClusterODM to use this directory:
C:\Users\sudodou\ODMProject\datasets\E8\images where images holds the data to be distributed.
I’ve tried quite a lot of combinations, but none have worked out. Some of the times the directory code is created, why?
I seem to have resolved the issue, while observing a few others. I will update later!
Welcome! Glad you got yourself sorted!
Please keep us posted on your progress!
