Hi Guys,
so far i work with on WebODM but now i would like tu use --split option with self set images_group.txt and distribute work witch ClusterODM on two computers.
like i understood for this i need to use odm, nodeodm and clusterodm?
what i do:
computer1 (the main machine): installed ubuntu 18.04 and:
runing nodeODM via docker
docker run -ti -p 3000:3000 opendronemap/nodeodm
runing ClusterODM via docker
docker run -ti -p 3001:3000 -p 8080:8080 opendronemap/clusterodm
computer2: installed ubuntu 18.04 and:
next i am going to computer1 and via telnet connect to ClusterODM CLI and add the node
(via telnet cli on port 8080 work well, but the port 10000 on web browser do not work)
the both node are online. so far all looks easy.
or i make mistake?
Now when i have runing NodeODM on both machine and prepared ClusterODM i go to new window in terminal and would like to start work with ODM and distribute work to ClusterODM
i prepare folder the folder which contains images and images_group.txt
finally i run:
docker run -ti --rm -v /home/lot/test:/datasets opendronemap/odm --project-path /datasets project --split 50 --split-overlap 0 --sm-cluster http://192.168.0.214:3001
and now is the thing that i don’t understand. in docs (https://docs.opendronemap.org/large.html)
can read info:
“Make sure to pass --split-overlap 0
if you manually provide a image_groups.txt
file.”
should it work? in my logic i should set --split 0
and --split-overlap 100
to use images_group.txt ?
thanks
pawel
