ok so i uploaded a panorama to DroneDB, however it just shows as a black screen when i try to view it, here’s the DroneDB Link
Exif info in pic below
https://hub.dronedb.app/r/martinr36/wdg7t6tb7toymrke
I’m using Waterfox, what are you using, in out mobile at the moment, so I’ll check it in Firefox mobile
Chrome Desktop.
Make sure you allow-list hub.dronedb.app for any JavaScript filtering extensions you may have like Ghostery, JShelter, etc.
These are the only extensions that I have, got it sort of to open in edge, and mobile firerfox, but as @pierotfy says, the projection is way off
The distortion is due to the projection type of the image, which is cylindrical, but the software doesn’t support it (it supports only equirectangular). As a workaround, if your panorama software allows it, export the panorama using a equirectangular projection until we implement Add support for cylindrical panorama projections · Issue #79 · DroneDB/Hub · GitHub
Well this is getting even weirder, I managed to get it to display ok in the waterfox browser on my desktop, but not on the laptop (identical setup), this is shown in the first image below, then i tried it again a few minutes later and got the result in the second image, look closely where I’ve circled it and there is something there
Ok this is looking like a waterfox problem as it works ok in firefox, and I’ve remade it so should display properly now
