Thanks for replying. No change. I have attempted these parameters:
docker run -i -v /home/ianmcnish/rgb_gcp_list.txt:/code/images/rgb_gcp_list.txt -v /home/ianmcnish/:/code/images -v /home/ianmcnish/:/code/odm_orthophoto -v /home/ianmcnish/:/code/odm_texturing opendronemap/odm --gcp /code/images/rgb_gcp_list.txt --fast-orthophoto --min-num-features 60000 --ignore-gsd --matcher-neighbors 16 --matcher-distance 60 --texturing-nadir-weight 8
Here is the output. I trimmed it to fit in the forum.
[INFO] Fast orthophoto is turned on, automatically setting --skip-3dmodel
[INFO] Initializing OpenDroneMap app - Tue Dec 17 20:41:54 2019
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: True
[INFO] force_gps: False
[INFO] gcp: /code/images/rgb_gcp_list.txt
[INFO] ignore_gsd: True
[INFO] matcher_distance: 60
[INFO] matcher_neighbors: 16
[INFO] max_concurrency: 10
[INFO] merge: all
[INFO] mesh_octree_depth: 9
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 100000
[INFO] min_num_features: 60000
[INFO] mve_confidence: 0.6
[INFO] name: code
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_sample: 0
[INFO] project_path: /
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] texturing_nadir_weight: 8
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /code/images
[INFO] Loading 54 images
[INFO] Wrote images database: /code/images.json
[INFO] Found 54 usable images
[INFO] Parsing SRS header: EPSG:32615
[INFO] Generated coords file from GCP: WGS84 UTM 15N
[INFO] Parsing SRS header: WGS84 UTM 15N
[INFO] 20 GCP points will be used for georeferencing
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] ['use_exif_size: no', 'feature_process_size: 2048', 'feature_min_frames: 60000', 'processes: 10', 'matching_gps_neighbors: 16', 'matching_gps_distance: 60', 'depthmap_method: PATCH_MATCH', 'depthmap_resolution: 640', 'depthmap_min_patch_sd: 1', 'depthmap_min_consistent_views: 3', 'optimize_camera_parameters: yes', 'undistorted_image_format: png', 'bundle_outlier_filtering_type: AUTO', 'align_orientation_prior: vertical', 'use_altitude_tag: yes', 'align_method: auto', 'local_bundle_radius: 0', 'bundle_use_gcp: yes', 'bundle_use_gps: no']
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata "/code/opensfm"
2019-12-17 20:41:56,039 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00110.jpg
2019-12-17 20:41:56,063 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00116.jpg
2019-12-17 20:41:56,066 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00076.jpg
2019-12-17 20:41:56,069 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00107.jpg
2019-12-17 20:41:56,071 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00087.jpg
2019-12-17 20:41:56,074 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00011.jpg
2019-12-17 20:41:56,077 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00074.jpg
2019-12-17 20:41:56,080 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00005.jpg
2019-12-17 20:41:56,082 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00120.jpg
2019-12-17 20:41:56,085 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00084.jpg
2019-12-17 20:41:56,088 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00072.jpg
2019-12-17 20:41:56,090 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00152.jpg
2019-12-17 20:41:56,093 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00097.jpg
2019-12-17 20:41:56,096 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00131.jpg
2019-12-17 20:41:56,099 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00004.jpg
2019-12-17 20:41:56,101 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00128.jpg
2019-12-17 20:41:56,104 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00006.jpg
2019-12-17 20:41:56,107 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00088.jpg
2019-12-17 20:41:56,110 INFO: Extracting EXIF for calibrated_0cae8e93088d_FW00154.jpg
2019-12-17 20:41:57,640 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00110.jpg
2019-12-17 20:41:57,970 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00116.jpg
2019-12-17 20:41:58,292 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00076.jpg
2019-12-17 20:41:58,625 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00107.jpg
2019-12-17 20:41:59,143 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00087.jpg
2019-12-17 20:41:59,469 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00011.jpg
2019-12-17 20:41:59,810 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00074.jpg
2019-12-17 20:42:00,276 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00005.jpg
2019-12-17 20:42:00,779 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00120.jpg
2019-12-17 20:42:01,294 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00084.jpg
2019-12-17 20:42:05,762 DEBUG: Found 27470 points in 8.09183502197s
2019-12-17 20:42:05,769 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00110.jpg, no features masked.
2019-12-17 20:42:06,046 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00072.jpg
2019-12-17 20:42:06,629 DEBUG: Found 26867 points in 8.62837004662s
2019-12-17 20:42:06,634 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00116.jpg, no features masked.
2019-12-17 20:42:06,910 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00152.jpg
2019-12-17 20:42:07,090 DEBUG: Found 27574 points in 8.76607203484s
2019-12-17 20:42:07,096 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00076.jpg, no features masked.
2019-12-17 20:42:07,425 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00097.jpg
2019-12-17 20:42:07,931 DEBUG: Found 28703 points in 9.27611589432s
2019-12-17 20:42:07,937 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00107.jpg, no features masked.
2019-12-17 20:42:08,222 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00131.jpg
2019-12-17 20:42:08,434 DEBUG: Found 25776 points in 8.92405080795s
2019-12-17 20:42:08,440 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00011.jpg, no features masked.
2019-12-17 20:42:08,714 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00004.jpg
2019-12-17 20:42:08,807 DEBUG: Found 27609 points in 9.61218214035s
2019-12-17 20:42:08,813 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00087.jpg, no features masked.
2019-12-17 20:42:08,961 DEBUG: Found 26844 points in 9.10031795502s
2019-12-17 20:42:08,968 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00074.jpg, no features masked.
2019-12-17 20:42:09,118 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00128.jpg
2019-12-17 20:42:09,279 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00006.jpg
2019-12-17 20:42:09,805 DEBUG: Found 26790 points in 9.47175383568s
2019-12-17 20:42:09,811 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00005.jpg, no features masked.
2019-12-17 20:42:10,098 INFO: Extracting ROOT_HAHOG features for image calibrated_0cae8e93088d_FW00088.jpg
2019-12-17 20:42:10,216 DEBUG: Found 27368 points in 9.38525605202s
2019-12-17 20:42:10,222 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00120.jpg, no features masked.
2019-12-17 20:44:25,962 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00006.jpg, no features masked.
2019-12-17 20:44:26,242 DEBUG: Matching calibrated_0cae8e93088d_FW00095.jpg and calibrated_0cae8e93088d_FW00109.jpg. Matcher: FLANN T-desc: 8.185 T-robust: 0.005 T-total: 8.190 Matches: 1502 Robust: 1484 Success: True
2019-12-17 20:44:26,439 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00006.jpg, no features masked.
2019-12-17 20:44:28,609 DEBUG: Matching calibrated_0cae8e93088d_FW00141.jpg and calibrated_0cae8e93088d_FW00129.jpg. Matcher: FLANN T-desc: 10.412 T-robust: 0.010 T-total: 10.422 Matches: 1482 Robust: 1457 Success: True
2019-12-17 20:44:28,714 DEBUG: Matching calibrated_0cae8e93088d_FW00008.jpg and calibrated_0cae8e93088d_FW00010.jpg. Matcher: FLANN T-desc: 8.422 T-robust: 0.013 T-total: 8.435 Matches: 2483 Robust: 2465 Success: True
2019-12-17 20:44:28,784 DEBUG: Matching calibrated_0cae8e93088d_FW00064.jpg and calibrated_0cae8e93088d_FW00073.jpg. Matcher: FLANN T-desc: 8.591 T-robust: 0.001 T-total: 8.593 Matches: 220 Robust: 201 Success: True
2019-12-17 20:44:28,806 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00154.jpg, no features masked.
2019-12-17 20:44:28,881 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00010.jpg, no features masked.
2019-12-17 20:44:28,934 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00006.jpg, no features masked.
2019-12-17 20:44:30,234 DEBUG: Matching calibrated_0cae8e93088d_FW00006.jpg and calibrated_0cae8e93088d_FW00076.jpg. Matcher: FLANN T-desc: 9.680 T-robust: 0.007 T-total: 9.687 Matches: 449 Robust: 425 Success: True
2019-12-17 20:44:30,388 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00073.jpg, no features masked.
2019-12-17 20:44:30,725 DEBUG: Matching calibrated_0cae8e93088d_FW00119.jpg and calibrated_0cae8e93088d_FW00129.jpg. Matcher: FLANN T-desc: 9.514 T-robust: 0.004 T-total: 9.518 Matches: 1080 Robust: 1060 Success: True
2019-12-17 20:44:30,797 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00141.jpg, no features masked.
2019-12-17 20:44:32,152 DEBUG: Matching calibrated_0cae8e93088d_FW00085.jpg and calibrated_0cae8e93088d_FW00107.jpg. Matcher: FLANN T-desc: 9.692 T-robust: 0.001 T-total: 9.693 Matches: 267 Robust: 245 Success: True
2019-12-17 20:44:32,290 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00075.jpg, no features masked.
2019-12-17 20:44:34,257 DEBUG: Matching calibrated_0cae8e93088d_FW00074.jpg and calibrated_0cae8e93088d_FW00006.jpg. Matcher: FLANN T-desc: 8.300 T-robust: 0.012 T-total: 8.312 Matches: 3246 Robust: 3211 Success: True
2019-12-17 20:44:34,377 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00005.jpg, no features masked.
2019-12-17 20:44:34,496 DEBUG: Matching calibrated_0cae8e93088d_FW00086.jpg and calibrated_0cae8e93088d_FW00009.jpg. Matcher: FLANN T-desc: 8.547 T-robust: 0.003 T-total: 8.550 Matches: 763 Robust: 744 Success: True
2019-12-17 20:44:34,561 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00088.jpg, no features masked.
2019-12-17 20:44:34,564 DEBUG: Matching calibrated_0cae8e93088d_FW00128.jpg and calibrated_0cae8e93088d_FW00131.jpg. Matcher: FLANN T-desc: 10.814 T-robust: 0.023 T-total: 10.837 Matches: 454 Robust: 432 Success: True
2019-12-17 20:44:34,719 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00140.jpg, no features masked.
2019-12-17 20:44:35,344 DEBUG: Matching calibrated_0cae8e93088d_FW00095.jpg and calibrated_0cae8e93088d_FW00006.jpg. Matcher: FLANN T-desc: 8.923 T-robust: 0.006 T-total: 8.929 Matches: 1240 Robust: 1174 Success: True
2019-12-17 20:44:35,476 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00004.jpg, no features masked.
2019-12-17 20:44:37,099 DEBUG: Matching calibrated_0cae8e93088d_FW00064.jpg and calibrated_0cae8e93088d_FW00010.jpg. Matcher: FLANN T-desc: 8.149 T-robust: 0.055 T-total: 8.204 Matches: 4226 Robust: 4162 Success: True
2019-12-17 20:44:37,268 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00066.jpg, no features masked.
2019-12-17 20:44:37,493 DEBUG: Matching calibrated_0cae8e93088d_FW00008.jpg and calibrated_0cae8e93088d_FW00006.jpg. Matcher: FLANN T-desc: 8.575 T-robust: 0.077 T-total: 8.652 Matches: 2179 Robust: 2159 Success: True
2019-12-17 20:44:37,791 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00066.jpg, no features masked.
2019-12-17 20:44:39,440 DEBUG: Matching calibrated_0cae8e93088d_FW00006.jpg and calibrated_0cae8e93088d_FW00073.jpg. Matcher: FLANN T-desc: 9.043 T-robust: 0.023 T-total: 9.066 Matches: 4858 Robust: 4848 Success: True
2019-12-17 20:44:39,498 DEBUG: Matching calibrated_0cae8e93088d_FW00141.jpg and calibrated_0cae8e93088d_FW00154.jpg. Matcher: FLANN T-desc: 10.701 T-robust: 0.012 T-total: 10.713 Matches: 568 Robust: 536 Success: True
2019-12-17 20:44:39,512 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00011.jpg, no features masked.
2019-12-17 20:44:39,652 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00155.jpg, no features masked.
2019-12-17 20:44:40,407 DEBUG: Matching calibrated_0cae8e93088d_FW00119.jpg and calibrated_0cae8e93088d_FW00141.jpg. Matcher: FLANN T-desc: 9.613 T-robust: 0.001 T-total: 9.615 Matches: 121 Robust: 97 Success: True
2019-12-17 20:44:40,552 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00131.jpg, no features masked.
2019-12-17 20:44:42,004 DEBUG: Matching calibrated_0cae8e93088d_FW00085.jpg and calibrated_0cae8e93088d_FW00075.jpg. Matcher: FLANN T-desc: 9.733 T-robust: 0.005 T-total: 9.738 Matches: 1535 Robust: 1516 Success: True
2019-12-17 20:44:42,149 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00084.jpg, no features masked.
2019-12-17 20:44:43,598 DEBUG: Matching calibrated_0cae8e93088d_FW00074.jpg and calibrated_0cae8e93088d_FW00005.jpg. Matcher: FLANN T-desc: 9.233 T-robust: 0.005 T-total: 9.237 Matches: 1302 Robust: 1279 Success: True
2019-12-17 20:44:43,697 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00010.jpg, no features masked.
2019-12-17 20:44:43,748 DEBUG: Matching calibrated_0cae8e93088d_FW00086.jpg and calibrated_0cae8e93088d_FW00088.jpg. Matcher: FLANN T-desc: 9.174 T-robust: 0.015 T-total: 9.190 Matches: 2735 Robust: 2660 Success: True
2019-12-17 20:44:43,844 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00007.jpg, no features masked.
2019-12-17 20:44:44,512 DEBUG: Matching calibrated_0cae8e93088d_FW00128.jpg and calibrated_0cae8e93088d_FW00140.jpg. Matcher: FLANN T-desc: 9.824 T-robust: 0.001 T-total: 9.825 Matches: 75 Robust: 62 Success: True
2019-12-17 20:44:44,516 DEBUG: Matching calibrated_0cae8e93088d_FW00095.jpg and calibrated_0cae8e93088d_FW00004.jpg. Matcher: FLANN T-desc: 9.013 T-robust: 0.035 T-total: 9.048 Matches: 2869 Robust: 2846 Success: True
2019-12-17 20:44:44,686 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00151.jpg, no features masked.
2019-12-17 20:44:44,717 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00094.jpg, no features masked.
2019-12-17 20:44:45,917 DEBUG: Matching calibrated_0cae8e93088d_FW00008.jpg and calibrated_0cae8e93088d_FW00066.jpg. Matcher: FLANN T-desc: 8.094 T-robust: 0.026 T-total: 8.120 Matches: 2005 Robust: 1982 Success: True
2019-12-17 20:44:46,060 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00072.jpg, no features masked.
2019-12-17 20:44:46,366 DEBUG: Matching calibrated_0cae8e93088d_FW00064.jpg and calibrated_0cae8e93088d_FW00066.jpg. Matcher: FLANN T-desc: 9.055 T-robust: 0.026 T-total: 9.081 Matches: 2176 Robust: 2132 Success: True
2019-12-17 20:44:46,615 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00065.jpg, no features masked.
2019-12-17 20:48:59,586 DEBUG: Matching calibrated_0cae8e93088d_FW00076.jpg and calibrated_0cae8e93088d_FW00011.jpg. Matcher: FLANN T-desc: 1.931 T-robust: 0.002 T-total: 1.933 Matches: 814 Robust: 766 Success: True
2019-12-17 20:48:59,593 DEBUG: No segmentation for calibrated_0cae8e93088d_FW00142.jpg, no features masked.
2019-12-17 20:49:01,137 DEBUG: Matching calibrated_0cae8e93088d_FW00076.jpg and calibrated_0cae8e93088d_FW00098.jpg. Matcher: FLANN T-desc: 1.549 T-robust: 0.001 T-total: 1.550 Matches: 353 Robust: 331 Success: True
2019-12-17 20:49:01,137 DEBUG: Image calibrated_0cae8e93088d_FW00076.jpg matches: 3 out of 3
2019-12-17 20:49:01,693 DEBUG: Matching calibrated_0cae8e93088d_FW00120.jpg and calibrated_0cae8e93088d_FW00142.jpg. Matcher: FLANN T-desc: 2.106 T-robust: 0.001 T-total: 2.107 Matches: 250 Robust: 231 Success: True
2019-12-17 20:49:01,693 DEBUG: Image calibrated_0cae8e93088d_FW00120.jpg matches: 3 out of 3
2019-12-17 20:49:01,753 DEBUG: Matched 496 pairs in 366.49555397 seconds.
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm create_tracks "/code/opensfm"
2019-12-17 20:49:02,502 INFO: reading features
2019-12-17 20:49:04,925 DEBUG: Merging features onto tracks
2019-12-17 20:49:10,776 DEBUG: Good tracks: 194612
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm reconstruct "/code/opensfm"
2019-12-17 20:49:44,614 INFO: Starting incremental reconstruction
2019-12-17 20:49:57,173 INFO: 0 partial reconstructions in total.
[INFO] Updating /code/opensfm/config.yaml
[INFO] undistorted_image_max_size: 1248
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm undistort "/code/opensfm"
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_visualsfm --undistorted --points "/code/opensfm"
File "/code/SuperBuild/src/opensfm/bin/opensfm", line 34, in <module>
command.run(args)
File "/code/SuperBuild/src/opensfm/opensfm/commands/export_visualsfm.py", line 30, in run
reconstructions = data.load_undistorted_reconstruction()
File "/code/SuperBuild/src/opensfm/opensfm/dataset.py", line 585, in load_undistorted_reconstruction
filename='undistorted_reconstruction.json')
File "/code/SuperBuild/src/opensfm/opensfm/dataset.py", line 575, in load_reconstruction
with io.open_rt(self._reconstruction_file(filename)) as fin:
File "/code/SuperBuild/src/opensfm/opensfm/io.py", line 555, in open_rt
return io.open(path, 'r', encoding='utf-8')
IOError: [Errno 2] No such file or directory: '/code/opensfm/undistorted_reconstruction.json'
File "/code/run.py", line 57, in <module>
app.execute()
File "/code/stages/odm_app.py", line 92, in execute
File "/code/opendm/types.py", line 370, in run
File "/code/opendm/types.py", line 351, in run
File "/code/stages/run_opensfm.py", line 70, in process
octx.run('export_visualsfm --undistorted --points')
File "/code/opendm/osfm.py", line 21, in run
File "/code/opendm/system.py", line 76, in run
Exception: Child returned 1
