I’m new to WebODM.
I’ve used the last 3 days to try to setup an WebODM environment.
My machine is a quite new Windows 10 home, 64bit
I’ve installed Docker Toolbox, and Python 3.8 without problems.
The Docker terminal starts without problems,
but when I issue the command:
‘git clone https://github.com/OpenDroneMap/WebODM --config core.autocrlf=input --depth 1’
it returns within 1 second to the Docker terminal window.
It shows just one message: ‘Cloning to WebODM’…
and if I try to cd webodm, it says that it does’nt exists.
If I on the other hand issues the command:
‘docker run -p 3000:3000 opendronemap/nodeodm’
it starts to build a complete and working NodeODM environment !
But I would rather make a working WebODM environment,
any idea what my problem can be ?
best regards…Ole
