Unable to compete large datasets
I have been trying to create an ortho map using 790 input drone images. The project keeps running out of memory. I used the following option on the last run: split: 280, fast-orthophoto: true, rerun-from: dataset
Docker resources are as follows 6 cpu’s of 8, 20 gm memory of 32, 1.5 gb page and 104 gb disk.
The program ran for 7hr 48 minutes. Needless to say very disappointing and un-usable for anything requiring a timely time.
Drone images are rgb images of crop cover.
WEBODM has been successful with default setting and 350 images.
What resolution are you requesting?
Related, you might want to help us try to fund better feature filtering:
https://fund.webodm.org/#/fund/1
Thanks for the speedy response.
I’m using the default setting. I’m not sure which parameter is the resolution to which you are referrig.
I ran again last night with only fast ortho and split=200 instead of split=280. It completed successfully in 9 hrs 42 min. The output looks good.
I only use ortho output so I guess that solves this problem for now
Glad you were able to find settings that work comfortably with your rig.
The split value is a little confusing, and now that you have run it with a smaller split it reveals what the likely issue was: you ran with a split of 280 assuming that, given you had successful 350 image processing, that 280 was a safe number. The tricky part is depending on the overlap between different submodels a 280 split could result in something much larger.
I am glad you got this working, and I will add this to troubleshooting recommendations for split merge.
Thank you for replying
Later
