I have been using the OpenDroneMap Master version, available on GitHub and my files were being used to create shapefiles. Everything was ok.
Now I have bought the WebODM Server version and my coordinates are crazy, I have created a shapefile to be used in Brazil and it is showing the Arctic Ocean instead. And I am doing everything exactly in the same way…
Anyone can help me ?
OLD ODM_GEOREFERENCING_MODEL_GEO.TXT FILE
WGS84 UTM 22S 225175.7832035 -2705871.4394130
NEW ODM_GEOREFERENCING_MODEL_GEO.TXT FILE
WGS84 UTM 22
804052.7064720 7317012.3457144
Both coordinates are in the same state there is no reason to be soooo different.
Anyone knows how to set the old coordinate pattern ?
Hey @accferronato
when did you last update/install WebODM? We fixed a bug with Southern Hemisphere coordinates ~3 weeks ago, maybe it’s related. https://github.com/OpenDroneMap/ODM/pull/941/files
Make sure you are running the latest version.
Hi, @pierotofy I installed on Saturday but I didn’t update it.
How do I do it? Just running the install script again?
And another question… It is impossible to run the WebODM server in here… I am running the normal OpenDroneMap when I try access localhost:80 to open WebODM server it show this error
FileNotFoundError at /
[Errno 2] No such file or directory: ‘webpack-cli’
Request Method: |
GET |
Request URL: |
http://localhost/ |
Django Version: |
2.1.7 |
Exception Type: |
FileNotFoundError |
Exception Value: |
[Errno 2] No such file or directory: ‘webpack-cli’ |
Exception Location: |
/usr/lib/python3.5/subprocess.py in _execute_child, line 1551 |
Python Executable: |
/webodm/python3-venv/bin/python3 |
Python Version: |
3.5.2 |
Python Path: |
[’/webodm’, ‘/webodm/python3-venv/bin’, ‘/webodm/python3-venv/lib/python35.zip’, ‘/webodm/python3-venv/lib/python3.5’, ‘/webodm/python3-venv/lib/python3.5/plat-x86_64-linux-gnu’, ‘/webodm/python3-venv/lib/python3.5/lib-dynload’, ‘/usr/lib/python3.5’, ‘/usr/lib/python3.5/plat-x86_64-linux-gnu’, ‘/webodm/python3-venv/lib/python3.5/site-packages’, ‘/webodm’] |
Server time: |
Tue, 26 Feb 2019 10:01:30 -0300 |
Make sure webpack-cli
has been installed by running:
sudo npm install -g webpack
sudo npm install -g webpack-cli
sudo ln -s $(which webpack) /usr/bin/webpack-cli
Another error now.
OSError at /welcome/
Error reading /webodm/webpack-stats.json. Are you sure webpack has generated the file and the path is correct?
Request Method: |
GET |
Request URL: |
http://localhost/welcome/ |
Django Version: |
2.1.7 |
Exception Type: |
OSError |
Exception Value: |
Error reading /webodm/webpack-stats.json. Are you sure webpack has generated the file and the path is correct? |
/webodm/python3-venv/lib/python3.5/site-packages/webpack_loader/loader.py in _load_assets, line 32 |
Python Version: |
3.5.2 |
Python Path: |
Server time: |
Ter, 26 Fev 2019 14:18:32 -0300 |
Error during template rendering
In template /webodm/app/templates/app/base.html
, error at line 25
15 <link href="{% static ‘app/css/metisMenu.min.css’ %}" rel=“stylesheet”>
16 <link href="{% static ‘app/css/sb-admin-2.css’ %}" rel=“stylesheet”>
17 {% block extra-headers %}{% endblock %}
18
19 <script src="{% static ‘app/js/vendor/modernizr-2.8.3.min.js’ %}"></script>
20 <script src="{% static ‘app/js/vendor/es6-shim.min.js’ %}"></script>
21 <script src="{% static ‘app/js/vendor/jquery-1.11.2.min.js’ %}"></script>
22 <script src="{% static ‘app/js/vendor/system.js’ %}"></script>
23
24 {% load render_bundle from webpack_loader %}
25 {% render_bundle ‘main’ %}
26
27 {% autoescape off %}
28 {% get_plugins_js_includes %}
29 {% get_plugins_css_includes %}
30 {% endautoescape %}
31
32 <title>{{title default:“Login”}} - {{ SETTINGS.app_name }}</title>
33
34 {% compress css %}
35 <link rel=“stylesheet” type=“text/x-scss” href="{% static ‘app/css/theme.scss’ %}" />
I thought the paid version would be easier to install and use.
@accferronato perhaps some of the commands in the installer didn’t complete successfully. Did you notice any error messages when running the installer for first time?
Follow these commands and try again.
cd /webodm
sudo su odm
git pull origin master
source python3-venv/bin/activate
npm install
pip install -r requirements.txt
webpack --mode production
python manage.py collectstatic --noinput
python manage.py migrate
