Seems that with default settings WebODM does not mount two flight data if it was taken in different weather conditions. Here is an example where you can see in the DronrDeploy mounted data that in WebODM unmounted strip is in different weather conditions. Are there any WebODM settings that can prevent this? There screenshots from both. DDeployJPG.JPG un 1 cits fails | Failiem.lv.
Hmm… You could try to increase --min-num-features, perhaps.
I tried to increase to 30000 but still missing two flight lines with sunny weather conditions (visible tree shadows instead of cloudy remaining flight lines).
Are you able to share the dataset?
