I have tried twice to process a project and I got the following error messages. There are over 500 images being processed.
Hi … im having the same problem …
I have tried several times … with different pictures …
each time its the same thing … process exited with code 1
If you try to process a smaller dataset (60-70 images), does it work? If so, you probably need more RAM.
RAM on my computer or on the server?
I have done another project with about 200 images. The first time, it didn’t process and I had to increase some memory. After I did that, it worked. Do I have to increase that every time? How?
