Trouble Starting WebODM
I can’t open WebODM after install. The logs are the following.
Original Text
No puedo abrir WEBODM después de actualizar los logs son los siguientes
"Booting WebODM 1.9.18 build 84..."
"Trying to connect to NodeODM localhost:29301..."
"nodeodm: info: Authentication using SimpleToken\r\n"
"nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\ninfo: No tasks dump found\r\ninfo: Checking for orphaned directories to be removed...\r\ninfo: Server has started on port 29301\r\n"
"Connected to NodeODM 2.2.1"
"redis-server:                 _._                                                  \n           _.-``__ ''-._                                             \n      _.-``    `.  `_.  ''-._           Redis 3.2.100 (00000000/0) 64 bit\n  .-`` .-```.  ```\\/    _.,_ ''-._                                   \n (    '      ,       .-`  | `,    )     Running in standalone mode\n |`-._`-...-` __...-.``-._|'` _.-'|     Port: 29379\n |    `-._   `._    /     _.-'    |     PID: 9092\n  `-._    `-._  `-./  _.-'    _.-'                                   \n |`-._`-._    `-.__.-'    _.-'_.-'|                                  \n |    `-._`-._        _.-'_.-'    |           http://redis.io        \n  `-._    `-._`-.__.-'_.-'    _.-'                                   \n |`-._`-._    `-.__.-'    _.-'_.-'|                                  \n |    `-._`-._        _.-'_.-'    |                                  \n  `-._    `-._`-.__.-'_.-'    _.-'                                   \n      `-._    `-.__.-'    _.-'                                       \n          `-._        _.-'                                           \n              `-.__.-'                                               \n\n[9092] 03 Apr 22:40:41.570 # Server started, Redis version 3.2.100\n[9092] 03 Apr 22:40:41.570 * The server is now ready to accept connections on port 29379\n"
"Trying to connect to postgres localhost:29543..."
"D:\\WebODM\\resources\\app\\apps\\pgsql/bin/psql: psql: FATAL:  password authentication failed for user \"postgres\"\r\n"
"D:\\WebODM\\resources\\app\\apps\\pgsql/bin/psql: exited with code 2"
"D:\\WebODM\\resources\\app\\apps\\pgsql/bin/pg_ctl: servidor inici ndose\r\n"
"Attempt 0 failed, retrying..."
"D:\\WebODM\\resources\\app\\apps\\pgsql/bin/pg_ctl: exited with code 0"
"Attempt 1 failed, retrying..."
"Attempt 2 failed, retrying..."
"Attempt 3 failed, retrying..."
"Attempt 4 failed, retrying..."
"Attempt 5 failed, retrying..."
"Attempt 6 failed, retrying..."
"Attempt 7 failed, retrying..."
"Attempt 8 failed, retrying..."
"Attempt 9 failed, retrying..."
LOG:  could not bind IPv6 socket: Only one usage of each socket address (protocol/network address/port) is normally permitted.
HINT:  Is another postmaster already running on port 29543? If not, wait a few seconds and retry.
LOG:  could not bind IPv4 socket: Only one usage of each socket address (protocol/network address/port) is normally permitted.
WARNING:  could not create listen socket for "localhost"
FATAL:  could not create any TCP/IP sockets
LOG:  database system is shut down
Normally a reboot will help. Can you try that?
Translation
Bienvenido!
Normalmente, un reboot es suficiente para esto. Puede tratarlo?
