Trouble installing on a Windows 10 Home laptop... can I run using the USB?
I have an Acer Nitro 5 laptop. It’s a pretty good lower end gaming machine. It has plenty of specs to run WebODM, but it’s running Windows 10 Home. Apparently I can’t run the virtual machines with this version. I bought the desktop install version of WebODM last night and I cannot get it to run under this OS. Upgrading to Windows 10 Pro is $100. The USB version of WebODM is $57. If I need to, I’ll buy the USB version if it will work. What do you guys think? Thank you!
the installer should run fine on Windows 10 Home. If you are getting an error, could you open the Help --> Contact Support menu from WebODM Manager and fill-in the information?
