Any idea?
Host: localhost
Port: 8000
Media directory: appmedia
Postgres DB directory: dbdata
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm=1
[+] Running 5/0
Container broker Created 0.0s
Container webodm-node-odm-1 Created 0.0s
Container db Created 0.0s
Container worker Created 0.0s
Container webapp Created 0.0s
Attaching to broker, db, webapp, webodm-node-odm-1, worker
db |
db | PostgreSQL Database directory appears to contain a database; Skipping initialization
db |
broker | 1:C 11 May 2023 15:53:14.074 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
broker | 1:C 11 May 2023 15:53:14.074 # Redis version=7.0.11, bits=64, commit=00000000, modified=0, pid=1, just started
broker | 1:C 11 May 2023 15:53:14.074 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
broker | 1:M 11 May 2023 15:53:14.076 # You requested maxclients of 10000 requiring at least 10032 max file descriptors.
broker | 1:M 11 May 2023 15:53:14.076 # Server can’t set maximum open files to 10032 because of OS error: Operation not permitted.
broker | 1:M 11 May 2023 15:53:14.076 # Current maximum open files is 4096. maxclients has been reduced to 4064 to compensate for low ulimit. If you need higher maxclients increase ‘ulimit -n’.
broker | 1:M 11 May 2023 15:53:14.076 * monotonic clock: POSIX clock_gettime
broker | 1:M 11 May 2023 15:53:14.095 * Running mode=standalone, port=6379.
broker | 1:M 11 May 2023 15:53:14.095 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
broker | 1:M 11 May 2023 15:53:14.095 # Server initialized
broker | 1:M 11 May 2023 15:53:14.095 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see vm.max_map_count growing steadily when vm.overcommit_memory is 2 · Issue #1328 · jemalloc/jemalloc · GitHub. To fix this issue add ‘vm.overcommit_memory = 1’ to /etc/sysctl.conf and then reboot or run the command ‘sysctl vm.overcommit_memory=1’ for this to take effect.
broker | 1:M 11 May 2023 15:53:14.227 * Loading RDB produced by version 7.0.11
broker | 1:M 11 May 2023 15:53:14.227 * RDB age 1297 seconds
broker | 1:M 11 May 2023 15:53:14.228 * RDB memory usage when created 0.56 Mb
broker | 1:M 11 May 2023 15:53:14.228 * Done loading RDB, keys loaded: 0, keys expired: 0.
broker | 1:M 11 May 2023 15:53:14.228 * DB loaded from disk: 0.132 seconds
broker | 1:M 11 May 2023 15:53:14.228 * Ready to accept connections
db | LOG: database system was shut down at 2023-05-11 15:31:37 UTC
db | LOG: MultiXact member wraparound protections are now enabled
db | LOG: database system is ready to accept connections
db | LOG: autovacuum launcher started
webodm-node-odm-1 | (node:1) NOTE: We are formalizing our plans to enter AWS SDK for JavaScript (v2) into maintenance mode in 2023.
webodm-node-odm-1 |
webodm-node-odm-1 | Please migrate your code to use AWS SDK for JavaScript (v3).
webodm-node-odm-1 | For more information, check the migration guide at Migrating your code to SDK for JavaScript V3 - AWS SDK for JavaScript
webodm-node-odm-1 | (Use node --trace-warnings ...
to show where the warning was created)
webodm-node-odm-1 | info: Authentication using NoTokenRequired
webodm-node-odm-1 | info: Listening on 0.0.0.0:6367 UDP for progress updates
webodm-node-odm-1 | info: Initialized 0 tasks
webodm-node-odm-1 | info: Checking for orphaned directories to be removed…
webodm-node-odm-1 | info: Server has started on port 3000
worker | psql: error: could not connect to server: Connection timed out
worker | Is the server running on host “db” (172.21.0.3) and accepting
worker | TCP/IP connections on port 5432?
worker | Postgres is unavailable - sleeping
webapp | psql: error: could not connect to server: Connection timed out
webapp | Is the server running on host “db” (172.21.0.3) and accepting
webapp | TCP/IP connections on port 5432?
webapp | Postgres is unavailable - sleeping
