To start over
Hi.
I have been using webodm for a couple of month now with great results (with the exception of GCPs, but thats another question I have and will define that in another topic).
My 1st problem is that the command ./webodm.sh start seem to have moved to another directory. I have no idea what I have done :slight_smile:
Also when trying out the new : Volume measurements are here! I will get an error that terrain model is missing. [I did create the map without GCPs]
I did run ./webodm.sh update.
So - I think I need to start over, but is there a way of starting over without reinstalling “everything”. What would be the best thing to do?
Regards Mattias
No need to start over, just make sure to check the “dsm” option in the preset when you create a task.
Okey thanks.
