Thermal Camera OrthoMapping Processing Failure
I have tried to cloud process 107 thermal R-TIFF images and I keep getting this error
Output could not be retrieved: HTTPSConnectionPool(host=‘spark1.webodm.net’, port=443): Read timed out. (read timeout=5)
Not sure what this means. I’ve turned off all options but 2D map.
Any help is appreciated.
Zee
If you login to your WebODM Lightning WebUI Dashboard, can you see the Task’s status?:
Hi and thanks for the reply, here is what it shows.
There is nothing in the console output.
Thanks.
Z
Nothing at all? Even if you export it?
