Hi to all,
I’m trying to create a model from non-georeferenced photos (all metadata removed).
I have a set of measured GCPs in a local coordinates system and want to use them to derive all the parameters of the aero-triangulation process, so the photos can be undirstorted and the model can be adjusted with them.
I assigned a random UTM reference to my GCPs coordinates just because a georeference is needed for them.
Without any additional parameter I sent the task to a dockerized ODM machine.
As the photos are not georeferenced, it seems to me that the GCPs were not taken into account, because the computed internal parameters of the shots differ a lot from the original ones, and the model is not adjusted or geo-spatially located on the GCPs.
I work sometimes with non-georeferenced local coordinates systems. There is a way to adjust the rays bundles just from GCPs?
