I was playing around trying to change the theme of my WebODM setup, but none of the changes I make are applied. When I navigate away and then return the values I set are retained in the theme menu but none of the display is actually changing.
I’ve tried restarting WebODM as well as clearing my cache, but neither seemed to do the job?
On a related note, trying to delete the theme that is currently in use seems to give an internal server error page, with no explanation of why!
I appreciate this is minor and not related to functionality so it’s probably not a priority!!
