The webodm installation does not proceed.ㄴ
I bought a webodm intaller and installed it.
But I could not install webodm. The installation did not proceed because of the clipboard in the console window.
I installed it on the of Windows 10 home version.
I thank you for your dedication.
Initializing console…
SET DOCKER_TLS_VERIFY=1
SET DOCKER_HOST=tcp://192.168.99.100:2376
SET DOCKER_CERT_PATH=D:\docker-webodm\machines\webodm
SET DOCKER_MACHINE_NAME=webodm
SET COMPOSE_CONVERT_WINDOWS_PATHS=true
REM Run this command to configure your shell:
REM @FOR /f “tokens=*” %i IN (‘docker-machine --storage-path D:\docker-webodm env webodm’) DO @%i
Setup env variable: DOCKER_TLS_VERIFY=1
Setup env variable: DOCKER_HOST=tcp://192.168.99.100:2376
Setup env variable: DOCKER_CERT_PATH=D:\docker-webodm\machines\webodm
Setup env variable: DOCKER_MACHINE_NAME=webodm
Setup env variable: COMPOSE_CONVERT_WINDOWS_PATHS=true
