You clicked because of the title, didn’t you? Well fear not car fans, because I have for you a genuine survey, of a genuine Lamborghini, made from genuine yellow… plastic. Click bait? You-betcha.
So my son has this crappy toy Lamborghini that I took some freehand photos of using my camera phone with GPS turned off. I did this because I’ve been doing hundreds of surveys of various things and turning all the knobs on ODM to get a better understanding of what does what. Since I started, I’ve picked up the ODM book which I’d recommend - it would have saved me a lot of time if I had it when I started.
I couldn’t find a dataset that I could use for testing out the 3D modelling options in the way that I wanted, which was being able to add freehand photos to a regular model to improve the detail in some areas. All of the photos are freehand at various angles and pitches.
Dataset: https://dashboard.aerosurvey.co.nz/files/shared/222.tar.gz
Images: 73
Firstly, I know a lot of the options below contain Ortho / DEM options. I have some presets that I use for surveys for consistency.
So here’s the first try from a month or two ago. This one came out remarkably well; the best of the lot in fact, (which is the reason for this post):
Lambo (Original)
https://dashboard.aerosurvey.co.nz/public.cgi?S=222&T=8b0e533f-88c1-4b19-82f8-4dd38cc81c38
Options: fast-orthophoto: false, use-fixed-camera-params: true, resize-to: -1, dsm: true, dtm: true, crop: 10, use-3dmesh: true, depthmap-resolution: 800, dem-resolution: 2.0, orthophoto-resolution: 2.0
It’s not perfect, but under the circumstances I think the results are great. I left it at that for a while and focused on other survey tests, but I came back to the Lambo data a couple of weeks ago as I noticed that there were new presents in WebODM that I was keen to run the data through. I’d say that the new surveys are, uhhh, “different”. A muddy puddle? An overcooked egg? Modern art? You decide.
Lambo (3D Model)
https://dashboard.aerosurvey.co.nz/public.cgi?S=272&T=d032b931-b885-4403-af9a-29869624524d
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: true, resize-to: -1, dsm: false, dtm: false, crop: 10, use-3dmesh: true, dem-resolution: 2, orthophoto-resolution: 2, depthmap-resolution: 1000, opensfm-depthmap-min-patch-sd: 1, min-num-features: 8000, matcher-neighbors: 8, texturing-data-term: gmi, use-opensfm-dense: false, mesh-size: 600000, mesh-octree-depth: 11, texturing-nadir-weight: 16
Lambo (POI)
https://dashboard.aerosurvey.co.nz/public.cgi?S=273&T=cb9f31ec-2530-414e-9fe5-c772782a49db
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: true, resize-to: 2048, dsm: false, dtm: false, crop: 10, use-3dmesh: true, dem-resolution: 2, orthophoto-resolution: 2, depthmap-resolution: 800, opensfm-depthmap-min-patch-sd: 1, min-num-features: 8000, matcher-neighbors: 24, texturing-data-term: gmi, use-opensfm-dense: false, mesh-size: 600000, mesh-octree-depth: 9, texturing-nadir-weight: 16
Lambo (Forest)
https://dashboard.aerosurvey.co.nz/public.cgi?S=286&T=421f893c-81af-4485-8b34-4ec9076da16a
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: true, resize-to: 2048, dsm: false, dtm: false, crop: 10, use-3dmesh: false, dem-resolution: 5, orthophoto-resolution: 5, depthmap-resolution: 1000, opensfm-depthmap-min-patch-sd: 1, min-num-features: 18000, matcher-neighbors: 21, texturing-data-term: area, use-opensfm-dense: false, mesh-size: 100000, mesh-octree-depth: 9, texturing-nadir-weight: 16
Lambo (Buildings)
https://dashboard.aerosurvey.co.nz/public.cgi?S=287&T=3caaba6d-50d1-4ffb-ab01-d764f31d3d9d
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: true, resize-to: 2048, dsm: false, dtm: false, crop: 10, use-3dmesh: true, dem-resolution: 2, orthophoto-resolution: 2, depthmap-resolution: 1000, opensfm-depthmap-min-patch-sd: 1, min-num-features: 8000, matcher-neighbors: 8, texturing-data-term: gmi, use-opensfm-dense: false, mesh-size: 300000, mesh-octree-depth: 10, texturing-nadir-weight: 28, rerun-from: odm_orthophoto
Lambo (SFM) - This one is actually good, though noisy.
https://dashboard.aerosurvey.co.nz/public.cgi?S=305&T=3e2a3c24-fa64-49e6-9074-be9c342bd358
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: true, resize-to: -1, dsm: true, dtm: true, crop: 10, use-3dmesh: true, dem-resolution: 2, orthophoto-resolution: 2, depthmap-resolution: 800, opensfm-depthmap-min-patch-sd: 1, min-num-features: 8000, matcher-neighbors: 8, texturing-data-term: gmi, use-opensfm-dense: true, mesh-size: 100000, mesh-octree-depth: 9, texturing-nadir-weight: 16
Lambo (TDT-A) - Texturing Data Term: Area; This one has done a fantastic job at recreating the fence… and the egg.
https://dashboard.aerosurvey.co.nz/public.cgi?S=306&T=18251052-f827-4742-a484-4e2fa2016d29
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: false, resize-to: -1, dsm: true, dtm: true, crop: 10, use-3dmesh: true, dem-resolution: 2, orthophoto-resolution: 2, depthmap-resolution: 800, opensfm-depthmap-min-patch-sd: 1, min-num-features: 8000, matcher-neighbors: 8, texturing-data-term: area, use-opensfm-dense: false, mesh-size: 100000, mesh-octree-depth: 9, texturing-nadir-weight: 16
Lambo (Volume)
https://dashboard.aerosurvey.co.nz/public.cgi?S=309&T=62d3da8d-d748-4ac4-9ec4-e8e697a06e5c
Options: fast-orthophoto: false, use-hybrid-bundle-adjustment: false, use-fixed-camera-params: true, resize-to: -1, dsm: true, dtm: false, crop: 10, use-3dmesh: false, dem-resolution: 2, orthophoto-resolution: 2, depthmap-resolution: 1000, opensfm-depthmap-min-patch-sd: 0, min-num-features: 8000, matcher-neighbors: 8, texturing-data-term: gmi, use-opensfm-dense: true, mesh-size: 100000, mesh-octree-depth: 9, texturing-nadir-weight: 16
Lambo (Hi-Res) - The same options as the original survey…
https://dashboard.aerosurvey.co.nz/public.cgi?S=285&T=17367f76-0ece-409b-9bcf-94e5719e620a
Options: resize-to: -1, use-3dmesh: true, orthophoto-resolution: 2.0, dtm: true, dem-resolution: 2.0, crop: 10, dsm: true, depthmap-resolution: 800, use-fixed-camera-params: true
Original options and it’s… still an egg? Somebody’s having a yoke and my eggspence.
I’ll have a fiddle with the options on the good ones and see how good I can get it.
