Good Day,
I have been experimenting with settings now that I have 256gb of RAM under the hood of my workstation, and have ran into some interesting results after tweaking the settings in a way that I expected to produce a better result. This is regarding one such instance.
I am running the newest WebODM version through Docker under Hyper-V on Windows 10 Pro. Workstation has ~220gb of RAM and 1.3TB of hard drive space allocated to Docker/Webodm. Can upload the images, but would prefer not to publicly post them at this time. Dropbox link is below; the files included are as follows:
-Settings - shows settings for a number of tasks ran for the same dataset with differing settings. All projects produced a good ortho/result with good GPS locations except for the bottom. âScrewyâ indicates the âbadâ project task, and âGoodâ indicates a proper result from the top task on this list.
-Good_Map and Good_Cameras - the resulting ortho and camera GPS locations from the top task
-Screwy_Map and Screwy_Cameras - the resulting ortho and camera GPS locations from the bottom âbadâ task.
-Logs_Screwy and Logs_Good - the console logs from each respective project.
Iâm hoping someone may be able to help me figure out which setting is causing the issues Iâm seeing. It appears that something with the bottom taskâs settings is causing the GPS locations of each image on the right side of the screen to go crazy, which appears to result in no data in those areas. Let me know if additional information is needed.
