Task failure, another case of "No proper input scene descriptor given"
33 hours into an attempt to create a 3D model of a landslip, the task has failed.
I’ve seen this same error a few times, but have no idea what causes it. Images are all in focus, drone was either stationary or moving at <8km/hr for all images, and there is a massive amount of overlap. Images were obtained from around 25m AGL.
Settings -
410 images 33:01:29
Cannot process dataset
|Options:|auto-boundary: true, dem-resolution: 1, dsm: true, dtm: true, feature-quality: ultra, gps-accuracy: 5, mesh-octree-depth: 13, mesh-size: 500000, min-num-features: 16000, orthophoto-resolution: 0.5, pc-quality: high, resize-to: -1, use-3dmesh: true|
End of the console log-
[INFO] Writing ODM Mesh file in: D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_meshing\odm_mesh.ply
[INFO] running “D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\PoissonRecon” --in “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_filterpoints\point_cloud.ply” --out “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_meshing\odm_mesh.dirty.ply” --depth 13 --pointWeight 4.0 --samplesPerNode 1.0 --threads 15 --bType 2 --linearFit
[WARNING] D:\a\ODM\ODM\SuperBuild\src\PoissonRecon\Src\FEMTree.IsoSurface.specialized.inl (Line 1896)
IsoSurfaceExtractor<3,float,struct VectorTypeUnion<float,struct Point<float,3>,struct Point > >::Extract
bad average roots: 7
[INFO] running “D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\ReconstructMesh” -i “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_meshing\odm_mesh.dirty.ply” -o “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_meshing\odm_mesh.ply” --remove-spikes 0 --remove-spurious 20 --smooth 0 --target-face-num 1000000 -v 0
[INFO] Finished odm_meshing stage
[INFO] Running mvs_texturing stage
[INFO] Writing MVS Textured file in: D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_texturing\odm_textured_model_geo.obj
[INFO] running “D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\texrecon” “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\opensfm\undistorted/reconstruction.nvm” “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_meshing\odm_mesh.ply” “D:\WebODM\resources\app\apps\NodeODM\data\a21f6596-13b2-43af-9bf1-6a072dcd7664\odm_texturing\odm_textured_model_geo” -d gmi -o gauss_clamping -t none --no_intermediate_results --max_texture_size=8192
D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\texrecon (built on Jul 29 2022, 19:52:13)
Load and prepare mesh:
Reading PLY: 468863 verts… 939591 faces… done.
Generating texture views:
No proper input scene descriptor given.
A input descriptor can be:
BUNDLE_FILE - a bundle file (currently onle .nvm files are supported)
SCENE_FOLDER - a folder containing images and .cam files
MVE_SCENE::EMBEDDING - a mve scene and embedding
Child returned 1
File “D:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 88, in execute
File “D:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 371, in run
[Previous line repeated 4 more times]
File “D:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 352, in run
File “D:\WebODM\resources\app\apps\ODM\stages\mvstex.py”, line 117, in process
system.run(’"{bin}" “{nvm_file}” “{model}” “{out_dir}” ’
File “D:\WebODM\resources\app\apps\ODM\opendm\system.py”, line 106, in run
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it.
All I could salvage from the task was a screen grab of odm_mesh.ply, which was rather disappointing!
Suggestions on how to avoid this error are most welcome :slight_smile:
I’ll have a go at another set I took, covering a larger area from ~50-60m AGL
Same problem here-
Link to the images? I’ll try them on my infrastructure.
Thanks Stephen, I’m uploading now, and will post a link when finished, which should be in about 5 hours over my slow internet.
Ran with defaults dsm/dtm fine. Rerunning now with just feature-quality turned up.
‘Feature_quality: ultra’ seems to be a common factor (100%) with this error, and although not every task using ultra feature quality fails, every one that did fail with ultra completed successfully when feature quality was set to high.
EDIT - UPDATE: as suspected, running high feature quality has allowed it to complete without error.
I’ll post results in The Showroom Landslip thread
