Having just installed a new RTX5070Ti, I thought I’d give a it a go with with a small set of images that I’ve used before, Which failed very quickly, I know that Cuda isn’t supported on the 50 series cards in WebODM, so was wondering if this maybe connected, console output below:
[INFO] Initializing ODM 3.5.5 - Mon Sep 01 09:06:47 2025
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] align: None
[INFO] auto_boundary: True
[INFO] auto_boundary_distance: 0
[INFO] bg_removal: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: dspsift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gltf: True
[INFO] gps_accuracy: 3
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_order: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 24
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: 05f2c273-4f23-4882-83cf-906e0e306ca8
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_skip_geometric: False
[INFO] primary_band: auto
[INFO] project_path: N:\WebODM\resources\app\apps\NodeODM\data\05f2c273-4f23-4882-83cf-906e0e306ca8
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] rolling_shutter: False
[INFO] sfm_no_partial: False
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] sm_no_align: False
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] texturing_single_material: False
[INFO] tiles: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] video_limit: 500
[INFO] video_resolution: 4000
[INFO] Running dataset stage
[INFO] Loading dataset from: N:\WebODM\resources\app\apps\NodeODM\data\05f2c273-4f23-4882-83cf-906e0e306ca8\images
[INFO] Loading 53 images
[INFO] Wrote images database: N:\WebODM\resources\app\apps\NodeODM\data\05f2c273-4f23-4882-83cf-906e0e306ca8\images.json
[INFO] Found 53 usable images
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 4000px
[INFO] Photo dimensions for feature extraction: 2000px
[INFO] CUDA drivers detected
[INFO] ['use_exif_size: no', 'flann_algorithm: KDTREE', 'feature_process_size: 2000', 'feature_min_frames: 10000', 'processes: 24', 'matching_gps_neighbors: 0', 'matching_gps_distance: 0', 'matching_graph_rounds: 50', 'optimize_camera_parameters: yes', 'reconstruction_algorithm: incremental', 'undistorted_image_format: tif', 'bundle_outlier_filtering_type: AUTO', 'sift_peak_threshold: 0.066', 'align_orientation_prior: vertical', 'triangulation_type: ROBUST', 'retriangulation_ratio: 2', 'matcher_type: FLANN', 'feature_type: DSPSIFT', 'use_altitude_tag: yes', 'align_method: auto', 'local_bundle_radius: 0']
[INFO] running "N:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm" detect_features "N:\WebODM\resources\app\apps\NodeODM\data\05f2c273-4f23-4882-83cf-906e0e306ca8\opensfm"
d:\a\odm\odm\superbuild\build\pypopsift\_deps\popsift-src\src\popsift\gauss_filter.cu:245
cudaMemcpyToSymbol failed for Gauss kernel initialization: unrecognized error code
