This is my first attempt to obtain something from webODM, and I got the following message:
[INFO] split_multitracks: False
[INFO] split_overlap: 150
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] ==============
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/2e1aa0bb-e5b1-44f4-b8bc-83004f9f9a9c/images
[INFO] Loading 382 images
[WARNING] Cannot read /var/www/data/2e1aa0bb-e5b1-44f4-b8bc-83004f9f9a9c/images/Mosaique Monlezun.tif with PIL, fallback to cv2: cannot identify image file ‘/var/www/data/2e1aa0bb-e5b1-44f4-b8bc-83004f9f9a9c/images/Mosaique Monlezun.tif’
[ WARN:0] OpenCV TIFF: TIFFRGBAImageOK: Sorry, can not handle images with 32-bit samples Traceback (most recent call last):
File “/code/run.py”, line 62, in
app.execute()
File “/code/stages/odm_app.py”, line 95, in execute
File “/code/opendm/types.py”, line 331, in run self.process(self.args, outputs) File “/code/stages/dataset.py”, line 89, in process photos += [types.ODM_Photo(f)] File “/code/opendm/photo.py”, line 68, in init
self.parse_exif_values(path_file)
File “/code/opendm/photo.py”, line 231, in parse_exif_values self.width, self.height = get_image_size.get_image_size(_path_file)
File “/code/opendm/get_image_size.py”, line 19, in get_image_size width = img.shape[1]
AttributeError: ‘NoneType’ object has no attribute ‘shape’
Set of photos comes from a Delair DT18 UAV with a RGB sensor. They are all georeferenced.
Any clue?
Thanks a lot,
Laurent.
