My solution is to stop/delete the running task in webodm and then upload the downloaded zip file. I need to share the task so I need the link provided by Webodm.
I am running webodm natively and via Digital ocean server, Ubuntu 16 lts. I always use the Lightning node.
I did delete the task and uploaded the zipped file - so the task output/log are gone. I need to run it again if there is no way to get if from the do console?
