Because of hilly region in between the surveyed area, the photos could not overlap much. I have tried with few settings. I set matcher-distance and matcher-neighbors to 0 & min-num-features to 80000. Still the results were not fruitful.
Could you guys please suggest what are the other parameters I can tweak to get the full map?
I spent a lot of time today taking apart and putting back my computer and trying various things to reproduce a failure to process a lot of folks have been having due to a recent update.
Your images are downloaded, optimized, sanity-checked, and ready to go for tomorrow! I didn’t forget yet, haha.
Does your sUAS or Flight Planner allow you to do terrain following? QGroundControl for instance will.
My thoughts at the moment are that you might be best served to divide up your survey for these hills into maybe 2 or 3 sub-surveys with a bit of overlap between them, taken at appropriate altitudes above mean survey area elevation to ensure that they can all process together.
All but the highest part of the hill reconstructed.
So unfortunately, I don’t have any tricks to save these surveys, but I think you can make life easier for yourself going forward with a few tweaks to your flight planning.
