While under windows I could run up to about 150 pictures, I decided to change to Linux Mint. Is there anyplace with more specific directions on running (especially automatically)? When I try to run the webodm.sh start, I end with the following:
File “”, line 1, in
ImportError: No module named setuptools
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-HGqr7U/texttable/
