Suspicious AWS output in console during undistort stage
Dataset Unavailable to share. Problem is with multiple datasets so it is not dataset specific.
I can use the latest docker image for ODM and add AWS keys to the environment. Once the pipeline runs undistort, I get a lot of very suspicious messages in the console. They appear like below
2022-09-20 23:29:35,888 DEBUG: Undistorting image dji_0388.1661979447415.tiff
2022-09-20 23:29:35,889 DEBUG: Changing event name from before-parameter-build.route53 to before-parameter-build.route-53
2022-09-20 23:29:35,889 DEBUG: Changing event name from request-created.cloudsearchdomain.Search to request-created.cloudsearch-domain.Search
2022-09-20 23:29:35,890 DEBUG: Changing event name from docs.*.autoscaling.CreateLaunchConfiguration.complete-section to docs.*.auto-scaling.CreateLaunchConfiguration.complete-section
2022-09-20 23:29:35,875 DEBUG: Changing event name from creating-client-class.iot-data to creating-client-class.iot-data-plane
2022-09-20 23:29:35,891 DEBUG: Changing event name from before-parameter-build.logs.CreateExportTask to before-parameter-build.cloudwatch-logs.CreateExportTask
2022-09-20 23:29:35,872 DEBUG: Changing event name from before-call.apigateway to before-call.api-gateway
2022-09-20 23:29:35,892 DEBUG: Changing event name from before-call.apigateway to before-call.api-gateway
2022-09-20 23:29:35,879 DEBUG: Changing event name from request-created.machinelearning.Predict to request-created.machine-learning.Predict
2022-09-20 23:29:35,887 DEBUG: Changing event name from creating-client-class.iot-data to creating-client-class.iot-data-plane
2022-09-20 23:29:35,896 DEBUG: Changing event name from creating-client-class.iot-data to creating-client-class.iot-data-plane
2022-09-20 23:29:35,896 DEBUG: Changing event name from docs.*.logs.CreateExportTask.complete-section to docs.*.cloudwatch-logs.CreateExportTask.complete-section
2022-09-20 23:29:35,896 DEBUG: Changing event name from request-created.machinelearning.Predict to request-created.machine-learning.Predict
2022-09-20 23:29:35,901 DEBUG: Changing event name from before-parameter-build.autoscaling.CreateLaunchConfiguration to before-parameter-build.auto-scaling.CreateLaunchConfiguration
2022-09-20 23:29:35,898 DEBUG: Changing event name from before-parameter-build.autoscaling.CreateLaunchConfiguration to before-parameter-build.auto-scaling.CreateLaunchConfiguration
2022-09-20 23:29:35,899 DEBUG: Changing event name from before-call.apigateway to before-call.api-gateway
2022-09-20 23:29:35,900 DEBUG: Changing event name from before-call.apigateway to before-call.api-gateway
2022-09-20 23:29:35,900 DEBUG: Changing event name from before-parameter-build.cloudsearchdomain.Search to before-parameter-build.cloudsearch-domain.Search
2022-09-20 23:29:35,901 DEBUG: Changing event name from before-parameter-build.route53 to before-parameter-build.route-53
2022-09-20 23:29:35,897 DEBUG: Changing event name from request-created.machinelearning.Predict to request-created.machine-learning.Predict
2022-09-20 23:29:35,902 DEBUG: Changing event name from before-parameter-build.route53 to before-parameter-build.route-53
2022-09-20 23:29:35,902 DEBUG: Changing event name from request-created.machinelearning.Predict to request-created.machine-learning.Predict
2022-09-20 23:29:35,903 DEBUG: Changing event name from request-created.machinelearning.Predict to request-created.machine-learning.Predict
2022-09-20 23:29:35,903 DEBUG: Changing event name from docs.*.cloudsearchdomain.Search.complete-section to docs.*.cloudsearch-domain.Search.complete-section
2022-09-20 23:29:35,904 DEBUG: Changing event name from request-created.cloudsearchdomain.Search to request-created.cloudsearch-domain.Search
2022-09-20 23:29:35,904 DEBUG: Changing event name from before-parameter-build.autoscaling.CreateLaunchConfiguration to before-parameter-build.auto-scaling.CreateLaunchConfiguration
2022-09-20 23:29:35,905 DEBUG: Changing event name from request-created.cloudsearchdomain.Search to request-created.cloudsearch-domain.Search
2022-09-20 23:29:35,906 DEBUG: Changing event name from before-parameter-build.autoscaling.CreateLaunchConfiguration to before-parameter-build.auto-scaling.CreateLaunchConfiguration
2022-09-20 23:29:35,907 DEBUG: Changing event name from before-parameter-build.autoscaling.CreateLaunchConfiguration to before-parameter-build.auto-scaling.CreateLaunchConfiguration
2022-09-20 23:29:35,908 DEBUG: Changing event name from docs.*.autoscaling.CreateLaunchConfiguration.complete-section to docs.*.auto-scaling.CreateLaunchConfiguration.complete-section
2022-09-20 23:29:35,908 DEBUG: IMDS ENDPOINT: http://169.254.169.254/
2022-09-20 23:29:35,909 DEBUG: Changing event name from before-parameter-build.route53 to before-parameter-build.route-53
2022-09-20 23:29:35,909 DEBUG: Changing event name from docs.*.autoscaling.CreateLaunchConfiguration.complete-section to docs.*.auto-scaling.CreateLaunchConfiguration.complete-section
2022-09-20 23:29:35,911 DEBUG: Changing event name from before-parameter-build.logs.CreateExportTask to before-parameter-build.cloudwatch-logs.CreateExportTask
2022-09-20 23:29:35,912 DEBUG: Changing event name from request-created.cloudsearchdomain.Search to request-created.cloudsearch-domain.Search
2022-09-20 23:29:35,912 DEBUG: Looking for credentials via: env
This is very concerning to see because it only appears when I add data from AWS and have access keys in the environment.
I looked around for answers using keywords, but I could not find anything about this other than Suspicious output in log files · Issue #1523 · OpenDroneMap/ODM · GitHub
