I have not been able to find a working link to a supported server installation script for Ubuntu. Is one still available?
I have run the WebODM install script on a fresh Ubuntu 16.04 Desktop virtual machine. I do not get a successful webodm start.
(env) [email protected]:~/Downloads/DroneMapper/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
