Hola Israel!
Thanks for the suggestion, I tried using: split: 10, split-overlap: 100
but I still got the Process exited with code 1
, the log is as follows:
2020-10-15 15:03:38,372 DEBUG: Computing sift with threshold 0.1
2020-10-15 15:03:38,953 INFO: Extracting ROOT_SIFT features for image DJI_0184.JPG
File "/code/SuperBuild/src/opensfm/bin/opensfm", line 34, in <module>
command.run(args)
File "/code/SuperBuild/src/opensfm/opensfm/commands/detect_features.py", line 31, in run
parallel_map(detect, arguments, processes, 1)
File "/code/SuperBuild/src/opensfm/opensfm/context.py", line 41, in parallel_map
return Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File "/usr/local/lib/python3.6/dist-packages/joblib/parallel.py", line 934, in __call__
self.retrieve()
File "/usr/local/lib/python3.6/dist-packages/joblib/parallel.py", line 833, in retrieve
File "/usr/local/lib/python3.6/dist-packages/joblib/_parallel_backends.py", line 521, in wrap_future_result
return future.result(timeout=timeout)
File "/usr/lib/python3.6/concurrent/futures/_base.py", line 432, in result
return self.__get_result()
File "/usr/lib/python3.6/concurrent/futures/_base.py", line 384, in __get_result
raise self._exception
File "/usr/local/lib/python3.6/dist-packages/joblib/externals/loky/_base.py", line 625, in _invoke_callbacks
callback(self)
File "/usr/local/lib/python3.6/dist-packages/joblib/parallel.py", line 309, in __call__
self.parallel.dispatch_next()
File "/usr/local/lib/python3.6/dist-packages/joblib/parallel.py", line 731, in dispatch_next
if not self.dispatch_one_batch(self._original_iterator):
File "/usr/local/lib/python3.6/dist-packages/joblib/parallel.py", line 759, in dispatch_one_batch
self._dispatch(tasks)
File "/usr/local/lib/python3.6/dist-packages/joblib/parallel.py", line 716, in _dispatch
job = self._backend.apply_async(batch, callback=cb)
File "/usr/local/lib/python3.6/dist-packages/joblib/_parallel_backends.py", line 510, in apply_async
future = self._workers.submit(SafeFunction(func))
File "/usr/local/lib/python3.6/dist-packages/joblib/externals/loky/reusable_executor.py", line 151, in submit
fn, *args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/joblib/externals/loky/process_executor.py", line 1022, in submit
raise self._flags.broken
joblib.externals.loky.process_executor.TerminatedWorkerError: A worker process managed by the executor was unexpectedly terminated. This could be caused by a segmentation fault while calling the function or by an excessive memory usage causing the Operating System to kill the worker. The exit codes of the workers are {SIGKILL(-9), SIGKILL(-9), SIGKILL(-9), SIGKILL(-9), SIGKILL(-9), SIGKILL(-9), SIGKILL(-9)}
File "/code/run.py", line 68, in <module>
app.execute()
File "/code/stages/odm_app.py", line 95, in execute
File "/code/opendm/types.py", line 356, in run
File "/code/opendm/types.py", line 337, in run
File "/code/stages/splitmerge.py", line 59, in process
File "/code/opendm/osfm.py", line 272, in feature_matching
self.run('detect_features')
File "/code/opendm/osfm.py", line 22, in run
File "/code/opendm/system.py", line 79, in run
Exception: Child returned 1
I basically need a super high resolution, super clear and super big image of the field… thats why I’m flying at 10 meters… I’m considering even flying at 7meters. I still cannot get the same result as dronedeploy
