Stuck in a "no password supplied" loop in docker
Hey I followed all the instructions Here, and have been having a few different problems, some of them I believe were due to a slow connection. Today I have tried to start fresh by rebuilding webodm in git, and have been getting stuck at starting webapp, or it finishes and nothing happens, and is unaccessible from the web browser. Now, I am stuck in a password no supplied loop. I am on a windows 7 machine.
here is the error from the console:
       /"""""""""""""""""\___/ ===
       \______ o           __/
         \    \         __/
          \____\_______/
docker is configured to use the default machine with IP 192.168.99.100
For help getting started, check out the docs at https://docs.docker.com
Start interactive shell
[email protected] MINGW64 /c/WebODM (master)
$ ./ webodm.sh start
bash: ./: Is a directory
$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || dock
er-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-o
dm=1
Starting node-odm … done
Starting broker … done
Starting db … done
Starting worker … done
Starting webapp … done
$ ./webodm.sh restart
Restarting WebODM…
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml -f docker-com
pose.nodemicmac.yml down --remove-orphans
Stopping webapp … done
Stopping worker … done
Stopping broker … done
Stopping webodm_node-odm_1 … done
Stopping db … done
Removing webapp … done
Removing worker … done
Removing broker … done
Removing webodm_node-odm_1 … done
Removing db … done
Starting WebODM…
Host: localhost
Port: 8000
SSL: NO
SSL key:
SSL certificate:
Default Nodes: 1
dm=1
Starting db … done
ERROR: No containers to start
Creating webodm_node-odm_1 … done
Creating db … done
Creating broker … done
Creating worker … done
Creating webapp … done
Attaching to broker, db, webodm_node-odm_1, worker, webapp
broker | 1:C 23 Jun 2020 19:48:13.661 # oO0OoO0OoO0Oo Redis is starting oO0
OoO0OoO0Oo
broker | 1:C 23 Jun 2020 19:48:13.661 # Redis version=6.0.5, bits=64, commi
t=00000000, modified=0, pid=1, just started
broker | 1:C 23 Jun 2020 19:48:13.661 # Warning: no config file specified,
using the default config. In order to specify a config file use redis-server /pa
th/to/redis.conf
broker | 1:M 23 Jun 2020 19:48:13.692 * Running mode=standalone, port=6379.
broker | 1:M 23 Jun 2020 19:48:13.692 # WARNING: The TCP backlog setting of
511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower
value of 128.
broker | 1:M 23 Jun 2020 19:48:13.692 # Server initialized
broker | 1:M 23 Jun 2020 19:48:13.693 # WARNING overcommit_memory is set to
0! Background save may fail under low memory condition. To fix this issue add ’
vm.overcommit_memory = 1’ to /etc/sysctl.conf and then reboot or run the command
‘sysctl vm.overcommit_memory=1’ for this to take effect.
db |
db | PostgreSQL Database directory appears to contain a database; Skipp
ing initialization
db |
db | LOG: database system was shut down at 2020-06-23 19:48:04 UTC
db | LOG: MultiXact member wraparound protections are now enabled
db | LOG: autovacuum launcher started
node-odm_1 | info: Authentication using NoTokenRequired
node-odm_1 | info: Listening on 0.0.0.0:6367 UDP for progress updates
node-odm_1 | info: No tasks dump found
node-odm_1 | info: Checking for orphaned directories to be removed…
worker | Password for user postgres:
worker | psql: fe_sendauth: no password supplied
worker | Postgres is unavailable - sleeping
webapp | Password for user postgres:
webapp | psql: fe_sendauth: no password supplied
webapp | Postgres is unavailable - sleeping
Gracefully stopping… (press Ctrl+C again to force)
Killing webapp … done
Killing worker … done
Killing broker … done
Killing db … done
Killing webodm_node-odm_1 … done
Hi @ih8legal,
This is really a headache. When I started in ODM, just when the WebODM API came out was one of the problems I was facing (Docker Toolbox). In some of my readings of the Docker documentation, they mentioned that it was a tool that was going to be limited in the future (discontinued) and it was better to use it with Windows 10. For that and other reasons (Windows 7 support limited until January of last year, if my memory does not fail me) I switch to Windows 10 pro (recommended) to install / work with Docker for Windows. As of the update, the only problem I have is the limited memory of my PC with the Node-ODM (although at first it did not happen), but fortunately, I can also use the Node-MicMac.
I am not an expert, in fact, I am only using it for my degree project and I have found it great, my sincere thanks to ODM and the entire community.
I hope this can help you.
Regards,
