Strange error please help!
Hi all
Get this error message :slight_smile:
“Process exited with code 1” means that part of the processing failed. Sometimes it’s a problem with the dataset, sometimes it can be solved by tweaking the [Task Options](javascript:void(0):wink: and sometimes it might be a bug! If you need help, upload your images somewhere like [Dropbox] or [Google Drive] and [open a topic] on our community forum, making sure to include a [copy of your task’s output](javascript:void(0);). Our awesome contributors will try to help you!
logfile :
2020-05-13 18:06:11,205 INFO: -------------------------------------------------------
2020-05-13 18:06:11,227 INFO: DSC08248.JPG resection inliers: 226 / 324
2020-05-13 18:06:11,345 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 3.146929e+02, Final cost: 2.704776e+02, Termination: CONVERGENCE
2020-05-13 18:06:11,346 INFO: Adding DSC08248.JPG to the reconstruction
2020-05-13 18:06:11,465 INFO: -------------------------------------------------------
2020-05-13 18:06:11,475 INFO: DSC08249.JPG resection inliers: 108 / 150
2020-05-13 18:06:11,498 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 2.264187e+02, Final cost: 2.125254e+02, Termination: CONVERGENCE
2020-05-13 18:06:11,498 INFO: Adding DSC08249.JPG to the reconstruction
2020-05-13 18:06:11,609 INFO: -------------------------------------------------------
2020-05-13 18:06:11,617 INFO: DSC08250.JPG resection inliers: 52 / 99
2020-05-13 18:06:11,734 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 1.795199e+02, Final cost: 1.707772e+02, Termination: NO_CONVERGENCE
2020-05-13 18:06:11,734 INFO: Adding DSC08250.JPG to the reconstruction
2020-05-13 18:06:11,819 INFO: -------------------------------------------------------
2020-05-13 18:06:11,832 INFO: DSC08251.JPG resection inliers: 105 / 174
2020-05-13 18:06:11,949 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 2.064582e+02, Final cost: 1.897919e+02, Termination: CONVERGENCE
2020-05-13 18:06:11,949 INFO: Adding DSC08251.JPG to the reconstruction
2020-05-13 18:06:12,039 INFO: -------------------------------------------------------
2020-05-13 18:06:12,041 INFO: DSC08252.JPG resection inliers: 9 / 14
2020-05-13 18:06:12,042 INFO: DSC08266.JPG resection inliers: 7 / 7
2020-05-13 18:06:12,049 INFO: Some images can not be added
2020-05-13 18:06:12,050 INFO: -------------------------------------------------------
2020-05-13 18:06:12,050 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:13,343 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:38,943 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 7.303088e+03, Final cost: 6.583218e+02, Termination: NO_CONVERGENCE
2020-05-13 18:06:39,760 INFO: Removed outliers: 931
2020-05-13 18:06:40,143 INFO: {‘average_track_length’: 2.6887758777174304, ‘points_count’: 69413, ‘observations_count’: 186636, ‘cameras_count’: 44, ‘average_track_length_notwo’: 3.904401513642701}
2020-05-13 18:06:40,143 INFO: Starting reconstruction with DSC08258.JPG and DSC08259.JPG
2020-05-13 18:06:40,199 INFO: Two-view reconstruction inliers: 1177 / 1177
2020-05-13 18:06:40,289 INFO: Triangulated: 999
2020-05-13 18:06:40,322 DEBUG: Ceres Solver Report: Iterations: 2, Initial cost: 9.092848e+01, Final cost: 9.065460e+01, Termination: CONVERGENCE
2020-05-13 18:06:40,496 DEBUG: Ceres Solver Report: Iterations: 2, Initial cost: 9.073403e+01, Final cost: 9.060767e+01, Termination: CONVERGENCE
2020-05-13 18:06:41,175 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 2.651090e+01, Final cost: 2.502594e+01, Termination: NO_CONVERGENCE
2020-05-13 18:06:41,184 INFO: Removed outliers: 24
2020-05-13 18:06:41,185 INFO: -------------------------------------------------------
2020-05-13 18:06:41,199 INFO: DSC08260.JPG resection inliers: 109 / 124
2020-05-13 18:06:41,317 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 4.020456e+01, Final cost: 2.850101e+01, Termination: CONVERGENCE
2020-05-13 18:06:41,317 INFO: Adding DSC08260.JPG to the reconstruction
2020-05-13 18:06:41,386 INFO: Re-triangulating
2020-05-13 18:06:41,387 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:41,415 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:41,593 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 5.496837e+02, Final cost: 4.253656e+01, Termination: CONVERGENCE
2020-05-13 18:06:41,892 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:42,014 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 7.524535e+01, Final cost: 4.860589e+01, Termination: CONVERGENCE
2020-05-13 18:06:42,031 INFO: Removed outliers: 181
2020-05-13 18:06:42,032 INFO: -------------------------------------------------------
2020-05-13 18:06:42,039 INFO: DSC08261.JPG resection inliers: 84 / 95
2020-05-13 18:06:42,048 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 5.648916e+01, Final cost: 2.913386e+01, Termination: CONVERGENCE
2020-05-13 18:06:42,048 INFO: Adding DSC08261.JPG to the reconstruction
2020-05-13 18:06:42,106 INFO: Re-triangulating
2020-05-13 18:06:42,106 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:42,159 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:42,585 DEBUG: Ceres Solver Report: Iterations: 28, Initial cost: 3.025444e+02, Final cost: 7.505149e+01, Termination: CONVERGENCE
2020-05-13 18:06:43,006 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:43,204 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 1.842368e+02, Final cost: 9.237083e+01, Termination: CONVERGENCE
2020-05-13 18:06:43,229 INFO: Removed outliers: 233
2020-05-13 18:06:43,230 INFO: -------------------------------------------------------
2020-05-13 18:06:43,236 INFO: DSC08262.JPG resection inliers: 71 / 75
2020-05-13 18:06:43,239 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 6.007902e+01, Final cost: 3.278123e+01, Termination: CONVERGENCE
2020-05-13 18:06:43,239 INFO: Adding DSC08262.JPG to the reconstruction
2020-05-13 18:06:43,274 INFO: -------------------------------------------------------
2020-05-13 18:06:43,277 INFO: DSC08257.JPG resection inliers: 26 / 28
2020-05-13 18:06:43,394 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 1.739824e+01, Final cost: 1.486221e+01, Termination: CONVERGENCE
2020-05-13 18:06:43,394 INFO: Adding DSC08257.JPG to the reconstruction
2020-05-13 18:06:43,424 INFO: Re-triangulating
2020-05-13 18:06:43,425 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:43,475 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:44,693 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 7.188650e+02, Final cost: 1.116217e+02, Termination: NO_CONVERGENCE
2020-05-13 18:06:45,223 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:45,753 DEBUG: Ceres Solver Report: Iterations: 31, Initial cost: 3.276402e+02, Final cost: 1.627469e+02, Termination: CONVERGENCE
2020-05-13 18:06:45,787 INFO: Removed outliers: 348
2020-05-13 18:06:45,787 INFO: -------------------------------------------------------
2020-05-13 18:06:45,790 INFO: DSC08256.JPG resection inliers: 24 / 27
2020-05-13 18:06:45,907 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 3.965889e+01, Final cost: 2.893052e+01, Termination: CONVERGENCE
2020-05-13 18:06:45,908 INFO: Adding DSC08256.JPG to the reconstruction
2020-05-13 18:06:45,931 INFO: -------------------------------------------------------
2020-05-13 18:06:45,933 INFO: DSC08263.JPG resection inliers: 12 / 15
2020-05-13 18:06:46,089 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 2.449897e+01, Final cost: 2.350948e+01, Termination: CONVERGENCE
2020-05-13 18:06:46,089 INFO: Adding DSC08263.JPG to the reconstruction
2020-05-13 18:06:46,105 INFO: -------------------------------------------------------
2020-05-13 18:06:46,107 INFO: DSC08264.JPG resection inliers: 4 / 6
2020-05-13 18:06:46,110 INFO: Some images can not be added
2020-05-13 18:06:46,110 INFO: -------------------------------------------------------
2020-05-13 18:06:46,110 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:46,169 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:47,039 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 4.953588e+02, Final cost: 9.154577e+01, Termination: NO_CONVERGENCE
2020-05-13 18:06:47,074 INFO: Removed outliers: 269
2020-05-13 18:06:47,093 INFO: {‘average_track_length’: 2.029443838604144, ‘points_count’: 3668, ‘observations_count’: 7444, ‘cameras_count’: 8, ‘average_track_length_notwo’: 3.0}
2020-05-13 18:06:47,093 INFO: Starting reconstruction with DSC08252.JPG and DSC08253.JPG
2020-05-13 18:06:47,123 INFO: Two-view reconstruction inliers: 420 / 420
2020-05-13 18:06:47,173 INFO: Triangulated: 420
2020-05-13 18:06:47,178 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 4.529137e+01, Final cost: 4.523295e+01, Termination: CONVERGENCE
2020-05-13 18:06:47,266 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 4.524185e+01, Final cost: 4.521253e+01, Termination: CONVERGENCE
2020-05-13 18:06:47,325 DEBUG: Ceres Solver Report: Iterations: 15, Initial cost: 8.727593e+00, Final cost: 7.150635e+00, Termination: CONVERGENCE
2020-05-13 18:06:47,330 INFO: Removed outliers: 9
2020-05-13 18:06:47,331 INFO: -------------------------------------------------------
2020-05-13 18:06:47,334 INFO: DSC08254.JPG resection inliers: 40 / 40
2020-05-13 18:06:47,461 DEBUG: Ceres Solver Report: Iterations: 6, Initial cost: 8.748865e+00, Final cost: 1.623687e+00, Termination: CONVERGENCE
2020-05-13 18:06:47,461 INFO: Adding DSC08254.JPG to the reconstruction
2020-05-13 18:06:47,481 INFO: Re-triangulating
2020-05-13 18:06:47,481 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:47,492 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-05-13 18:06:47,701 DEBUG: Ceres Solver Report: Iterations: 33, Initial cost: 2.309452e+01, Final cost: 4.058589e+00, Termination: CONVERGENCE
2020-05-13 18:06:48,371 WARNING: Shots and/or GCPs are aligned on a single-line. Using vertical prior
2020-05-13 18:06:48,548 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 2.571422e+01, Final cost: 2.346826e+01, Termination: NO_CONVERGENCE
2020-05-13 18:06:48,556 INFO: Removed outliers: 12
2020-05-13 18:06:48,556 INFO: -------------------------------------------------------
2020-05-13 18:06:48,558 INFO: DSC08255.JPG resection inliers: 23 / 23
2020-05-13 18:06:48,676 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 2.382379e+00, Final cost: 4.092743e-01, Termination: CONVERGENCE
2020-05-13 18:06:48,676 INFO: Adding DSC08255.JPG to the reconstruction
2020-05-13 18:06:48,695 INFO: Re-triangulating
2020-05-13 18:06:48,696 WARNING: Shots and/or GCPs are aligned on a single-line. Using vertical prior
2020-05-13 18:06:48,709 WARNING: Shots and/or GCPs are aligned on a single-line. Using vertical prior
2020-05-13 18:06:49,002 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 3.293216e+01, Final cost: 2.729910e+01, Termination: NO_CONVERGENCE
2020-05-13 18:06:49,162 WARNING: Shots and/or GCPs are aligned on a single-line. Using vertical prior
2020-05-13 18:06:49,381 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 3.034066e+01, Final cost: 2.620103e+01, Termination: NO_CONVERGENCE
2020-05-13 18:06:49,389 INFO: Removed outliers: 11
2020-05-13 18:06:49,390 INFO: -------------------------------------------------------
2020-05-13 18:06:49,395 INFO: Some images can not be added
2020-05-13 18:06:49,395 INFO: -------------------------------------------------------
2020-05-13 18:06:49,396 WARNING: Shots and/or GCPs are aligned on a single-line. Using vertical prior
2020-05-13 18:06:49,409 WARNING: Shots and/or GCPs are aligned on a single-line. Using vertical prior
2020-05-13 18:06:49,726 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 2.915346e+01, Final cost: 2.727624e+01, Termination: NO_CONVERGENCE
2020-05-13 18:06:49,734 INFO: Removed outliers: 6
2020-05-13 18:06:49,738 INFO: {‘average_track_length’: 2.0672645739910314, ‘points_count’: 892, ‘observations_count’: 1844, ‘cameras_count’: 4, ‘average_track_length_notwo’: 3.0}
2020-05-13 18:06:49,738 INFO: Starting reconstruction with DSC08264.JPG and DSC08265.JPG
2020-05-13 18:06:49,753 INFO: Two-view reconstruction inliers: 105 / 106
2020-05-13 18:06:49,764 INFO: Triangulated: 105
2020-05-13 18:06:49,873 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 7.585198e+01, Final cost: 7.566066e+01, Termination: CONVERGENCE
2020-05-13 18:06:49,893 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 7.569284e+01, Final cost: 7.560473e+01, Termination: CONVERGENCE
2020-05-13 18:06:49,912 DEBUG: Ceres Solver Report: Iterations: 13, Initial cost: 5.014316e+00, Final cost: 1.857166e+00, Termination: CONVERGENCE
2020-05-13 18:06:49,914 INFO: Removed outliers: 0
2020-05-13 18:06:49,914 INFO: -------------------------------------------------------
2020-05-13 18:06:49,919 INFO: Some images can not be added
2020-05-13 18:06:49,919 INFO: -------------------------------------------------------
2020-05-13 18:06:50,047 DEBUG: Ceres Solver Report: Iterations: 51, Initial cost: 1.293255e+01, Final cost: 2.060611e+00, Termination: NO_CONVERGENCE
2020-05-13 18:06:50,049 INFO: Removed outliers: 0
2020-05-13 18:06:50,049 INFO: {‘average_track_length’: 2.0, ‘points_count’: 105, ‘observations_count’: 210, ‘cameras_count’: 2, ‘average_track_length_notwo’: -1}
2020-05-13 18:06:50,049 INFO: Reconstruction 0: 44 images, 49126 points
2020-05-13 18:06:50,050 INFO: Reconstruction 1: 44 images, 69413 points
2020-05-13 18:06:50,050 INFO: Reconstruction 2: 8 images, 3668 points
2020-05-13 18:06:50,050 INFO: Reconstruction 3: 4 images, 892 points
2020-05-13 18:06:50,050 INFO: Reconstruction 4: 2 images, 105 points
2020-05-13 18:06:50,050 INFO: 5 partial reconstructions in total.
[INFO] Updating /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/opensfm/config.yaml
[INFO] undistorted_image_max_size: 7360
[INFO] Undistorting /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/opensfm …
2020-05-13 18:07:09,289 DEBUG: Undistorting image DSC08229.JPG
2020-05-13 18:07:09,559 DEBUG: Undistorting image DSC08214.JPG
2020-05-13 18:07:09,831 DEBUG: Undistorting image DSC08230.JPG
2020-05-13 18:07:10,106 DEBUG: Undistorting image DSC08194.JPG
2020-05-13 18:07:10,385 DEBUG: Undistorting image DSC08216.JPG
2020-05-13 18:07:10,705 DEBUG: Undistorting image DSC08203.JPG
2020-05-13 18:07:11,018 DEBUG: Undistorting image DSC08237.JPG
2020-05-13 18:07:11,371 DEBUG: Undistorting image DSC08235.JPG
2020-05-13 18:07:12,287 DEBUG: Undistorting image DSC08219.JPG
2020-05-13 18:07:12,323 DEBUG: Undistorting image DSC08201.JPG
2020-05-13 18:07:12,342 DEBUG: Undistorting image DSC08202.JPG
2020-05-13 18:07:12,415 DEBUG: Undistorting image DSC08205.JPG
2020-05-13 18:07:12,781 DEBUG: Undistorting image DSC08224.JPG
2020-05-13 18:07:13,173 DEBUG: Undistorting image DSC08218.JPG
2020-05-13 18:07:13,432 DEBUG: Undistorting image DSC08199.JPG
2020-05-13 18:07:14,471 DEBUG: Undistorting image DSC08221.JPG
2020-05-13 18:07:14,567 DEBUG: Undistorting image DSC08212.JPG
2020-05-13 18:07:14,595 DEBUG: Undistorting image DSC08198.JPG
2020-05-13 18:07:14,610 DEBUG: Undistorting image DSC08220.JPG
2020-05-13 18:07:14,633 DEBUG: Undistorting image DSC08204.JPG
2020-05-13 18:07:14,995 DEBUG: Undistorting image DSC08211.JPG
2020-05-13 18:07:15,213 DEBUG: Undistorting image DSC08213.JPG
2020-05-13 18:07:15,762 DEBUG: Undistorting image DSC08195.JPG
2020-05-13 18:07:16,821 DEBUG: Undistorting image DSC08206.JPG
2020-05-13 18:07:17,107 DEBUG: Undistorting image DSC08236.JPG
2020-05-13 18:07:17,118 DEBUG: Undistorting image DSC08209.JPG
2020-05-13 18:07:17,253 DEBUG: Undistorting image DSC08225.JPG
2020-05-13 18:07:17,329 DEBUG: Undistorting image DSC08223.JPG
2020-05-13 18:07:17,601 DEBUG: Undistorting image DSC08222.JPG
2020-05-13 18:07:17,643 DEBUG: Undistorting image DSC08210.JPG
2020-05-13 18:07:18,366 DEBUG: Undistorting image DSC08228.JPG
2020-05-13 18:07:19,578 DEBUG: Undistorting image DSC08215.JPG
2020-05-13 18:07:19,759 DEBUG: Undistorting image DSC08231.JPG
2020-05-13 18:07:19,901 DEBUG: Undistorting image DSC08232.JPG
2020-05-13 18:07:19,922 DEBUG: Undistorting image DSC08234.JPG
2020-05-13 18:07:20,034 DEBUG: Undistorting image DSC08200.JPG
2020-05-13 18:07:20,178 DEBUG: Undistorting image DSC08233.JPG
2020-05-13 18:07:20,415 DEBUG: Undistorting image DSC08197.JPG
2020-05-13 18:07:20,852 DEBUG: Undistorting image DSC08227.JPG
2020-05-13 18:07:22,261 DEBUG: Undistorting image DSC08207.JPG
2020-05-13 18:07:22,590 DEBUG: Undistorting image DSC08208.JPG
2020-05-13 18:07:22,745 DEBUG: Undistorting image DSC08196.JPG
2020-05-13 18:07:22,792 DEBUG: Undistorting image DSC08217.JPG
2020-05-13 18:07:22,830 DEBUG: Undistorting image DSC08226.JPG
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm export_visualsfm --points “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/opensfm”
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm export_geocoords --transformation --proj ‘+proj=utm +zone=31 +datum=WGS84 +units=m +no_defs +type=crs’ “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/opensfm”
[INFO] Finished opensfm stage
[INFO] Running mve stage
[INFO] running /code/SuperBuild/src/elibs/mve/apps/makescene/makescene “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/opensfm/undistorted/reconstruction.nvm” “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve”
MVE Makescene (built on May 1 2020, 22:23:36)
Info: Detected VisualSFM bundle format.
NVM: Loading file…
NVM: Number of features: 49126
Creating output directories…
Writing MVE views…
Writing MVE view: view_0002.mve…
Writing MVE view: view_0004.mve…
Writing MVE view: view_0001.mve…
Writing MVE view: view_0005.mve…
Writing MVE view: view_0003.mve…
Writing MVE view: view_0007.mve…
Writing MVE view: view_0000.mve…
Writing MVE view: view_0006.mve…
Writing MVE view: view_0008.mve…
Writing MVE view: view_0009.mve…
Writing MVE view: view_0011.mve…
Writing MVE view: view_0015.mve…
Writing MVE view: view_0010.mve…
Writing MVE view: view_0013.mve…
Writing MVE view: view_0014.mve…
Writing MVE view: view_0012.mve…
Writing MVE view: view_0021.mve…
Writing MVE view: view_0018.mve…
Writing MVE view: view_0020.mve…
Writing MVE view: view_0017.mve…
Writing MVE view: view_0019.mve…
Writing MVE view: view_0023.mve…
Writing MVE view: view_0022.mve…
Writing MVE view: view_0016.mve…
Writing MVE view: view_0031.mve…
Writing MVE view: view_0024.mve…
Writing MVE view: view_0026.mve…
Writing MVE view: view_0025.mve…
Writing MVE view: view_0027.mve…
Writing MVE view: view_0029.mve…
Writing MVE view: view_0030.mve…
Writing MVE view: view_0028.mve…
Writing MVE view: view_0032.mve…
Writing MVE view: view_0034.mve…
Writing MVE view: view_0033.mve…
Writing MVE view: view_0038.mve…
Writing MVE view: view_0039.mve…
Writing MVE view: view_0037.mve…
Writing MVE view: view_0036.mve…
Writing MVE view: view_0035.mve…
Writing MVE view: view_0043.mve…
Writing MVE view: view_0040.mve…
Writing MVE view: view_0042.mve…
Writing MVE view: view_0041.mve…
Writing bundle file…
Writing bundle (44 cameras, 49126 features): /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/synth_0.out…
Done importing NVM file!
[INFO] running /code/SuperBuild/src/elibs/mve/apps/dmrecon/dmrecon -s3 --progress=fancy --local-neighbors=2 “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve”
MVE Depth Map Reconstruction (built on May 1 2020, 22:23:31)
Initializing scene with 44 views…
Initialized 44 views (max ID is 43), took 3ms.
Reading Photosynther file (44 cameras, 49126 features)…
Reconstructing all views…
0 of 44 completed (0.00%)
Global View Selection failed
4 of 44 completed (9.09%)
6 of 44 completed (13.64%)
7 of 44 completed (15.91%)
8 of 44 completed (18.18%)
12 of 44 completed (27.27%)
13 of 44 completed (29.55%)
14 of 44 completed (31.82%)
16 of 44 completed (36.36%)
17 of 44 completed (38.64%)
18 of 44 completed (40.91%)
20 of 44 completed (45.45%)
21 of 44 completed (47.73%)
22 of 44 completed (50.00%)
23 of 44 completed (52.27%)
25 of 44 completed (56.82%)
27 of 44 completed (61.36%)
28 of 44 completed (63.64%)
29 of 44 completed (65.91%)
30 of 44 completed (68.18%)
34 of 44 completed (77.27%)
37 of 44 completed (84.09%)
39 of 44 completed (88.64%)
44 of 44 completed (100.00%)
Reconstruction took 110354ms.
Saving views back to disc…
Saving views to MVE files… done.
[INFO] running /code/SuperBuild/src/elibs/mve/apps/scene2pset/scene2pset -F3 “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve” “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/mve_dense_point_cloud.ply”
MVE Scene to Pointset (built on May 1 2020, 22:23:45)
Using depthmap “depth-L3” and color image “undist-L3”
Processing view “0005” (with colors)…
Processing view “0010” (with colors)…
Processing view “0002” (with colors)…
Processing view “0001” (with colors)…
Processing view “0004” (with colors)…
Processing view “0009” (with colors)…
Processing view “0003” (with colors)…
Processing view “0000” (with colors)…
Processing view “0017” (with colors)…
Processing view “0013” (with colors)…
Processing view “0011” (with colors)…
Processing view “0014” (with colors)…
Processing view “0016” (with colors)…
Processing view “0018” (with colors)…
Processing view “0012” (with colors)…
Processing view “0015” (with colors)…
Processing view “0019” (with colors)…
Processing view “0020” (with colors)…
Processing view “0023” (with colors)…
Processing view “0021” (with colors)…
Processing view “0022” (with colors)…
Processing view “0025” (with colors)…
Processing view “0026” (with colors)…
Processing view “0027” (with colors)…
Processing view “0028” (with colors)…
Processing view “0029” (with colors)…
Processing view “0034” (with colors)…
Processing view “0037” (with colors)…
Processing view “0036” (with colors)…
Processing view “0031” (with colors)…
Processing view “0035” (with colors)…
Processing view “0030” (with colors)…
Processing view “0032” (with colors)…
Processing view “0033” (with colors)…
Processing view “0038” (with colors)…
Processing view “0039” (with colors)…
Processing view “0041” (with colors)…
Processing view “0040” (with colors)…
Processing view “0042” (with colors)…
Processing view “0043” (with colors)…
Writing final point set (1092 points)…
Writing PLY file (1092 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] running /code/SuperBuild/src/elibs/mve/apps/meshclean/meshclean -t0.6 --no-clean --component-size=0 “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/mve_dense_point_cloud.ply” “/var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/mve_dense_point_cloud.filtered.ply”
MVE FSSR Mesh Cleaning (built on May 1 2020, 22:24:18)
Loading mesh: /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/mve_dense_point_cloud.ply
PLY Loader: comment Export generated by libmve
Reading PLY: 1092 verts…
done.
Removing low-confidence geometry (threshold 0.6)…
Deleted 1092 low-confidence vertices.
Writing mesh: /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/mve_dense_point_cloud.filtered.ply
Writing PLY file (0 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] Finished mve stage
[INFO] Filtering point cloud (statistical, meanK 16, standard deviation 2.5)
[INFO] running /code/build/bin/odm_filterpoints -inputFile /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/mve/mve_dense_point_cloud.ply -outputFile /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_filterpoints/point_cloud.ply -sd 2.5 -meank 16 -sample 0
[INFO] Writing ODM Mesh file in: /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_meshing/odm_mesh.ply
[INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_filterpoints/point_cloud.ply --out /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_meshing/odm_mesh.dirty.ply --depth 10 --pointWeight 4 --samplesPerNode 1.0 --threads 7 --linearFit
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_meshing/odm_mesh.dirty.ply -outputFile /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 200000
ERROR: In /build/vtk6-YpT4yb/vtk6-6.2.0+dfsg1/IO/PLY/vtkPLYWriter.cxx, line 114
vtkPLYWriter (0xeddcc0): No data to write!
[INFO] Writing ODM 2.5D Mesh file in: /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_meshing/odm_25dmesh.ply
[INFO] ODM 2.5D DSM resolution: 0.08
[INFO] Created temporary directory: /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_meshing/tmp
[INFO] running pdal info /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_filterpoints/point_cloud.ply > /tmp/tmp54FRqS.json
File “/code/run.py”, line 61, in
app.execute()
File “/code/opendm/types.py”, line 344, in run
File “/code/opendm/types.py”, line 325, in run
File “/code/stages/odm_meshing.py”, line 75, in process
smooth_dsm=not args.fast_orthophoto)
File “/code/opendm/mesh.py”, line 35, in create_25dmesh
apply_smoothing=smooth_dsm
File “/code/opendm/dem/commands.py”, line 92, in create_dem
extent = point_cloud.get_extent(input_point_cloud)
File “/code/opendm/point_cloud.py”, line 90, in get_extent
if bbox is None: raise Exception(“Cannot compute bounds for %s (bbox key missing)” % input_point_cloud)
Exception: Cannot compute bounds for /var/www/data/2d4d6835-fb3d-445b-b583-effebeb4c757/odm_filterpoints/point_cloud.ply (bbox key missing)
Hi!
This would help a lot.
i will tomorrow thx
