Attempting to process a very small part of a mapping job, 327 images into an orthophoto, but it failed after 5h 45m. Options as below, and below that the error details.
96GB RAM, so no shortage of available memory
Any help appreciated!
Processing Node: node-odm-1 (manual)
Options: dem-resolution: 2.0, dsm: true, feature-quality: ultra, ignore-gsd: true, orthophoto-resolution: 2.0, pc-quality: ultra
[INFO] Estimating depthmaps
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\DensifyPointCloud “C:\WebODM\resources\app\apps\NodeODM\data\3faeeede-f8fe-4bc3-961e-26e4e1363fe8\opensfm\undistorted\openmvs\scene.mvs” --resolution-level 1 --min-resolution 2736 --max-resolution 5472 --max-threads 16 --number-views-fuse 2 -w “C:\WebODM\resources\app\apps\NodeODM\data\3faeeede-f8fe-4bc3-961e-26e4e1363fe8\opensfm\undistorted\openmvs\depthmaps” -v 0 --geometric-iters 0
Child returned 3221226505
File “C:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 89, in execute
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 340, in run
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 321, in run
File “C:\WebODM\resources\app\apps\ODM\stages\openmvs.py”, line 79, in process
system.run(’%s “%s” %s’ % (context.omvs_densify_path,
File “C:\WebODM\resources\app\apps\ODM\opendm\system.py”, line 106, in run
opendm.system.SubprocessException: Child returned 3221226505
[ERROR] The program exited with a strange error code. Please report it at https://community.opendronemap.org
When I finish there will probably be over 20000 images in this job, which I wont have to process into the final ortho, but I’m attempting to do some quality control on each flight plan area as I go to ensure I have good coverage. Large variations in ground elevation across the 1400ha area I have to cover, which makes planning fairly complex.
