'str' object has no attribute 'den' cannot read extended exf file
Some console logs from the start, anyone knows if this is a problem ? and if yes, why this is and what to do about it ?
[WARNING] Cannot read extended EXIF tags for DJI_0284.JPG: ‘str’ object has no attribute ‘den’
[WARNING] Cannot read extended EXIF tags for DJI_0310.JPG: ‘bytes’ object has no attribute ‘den’
[WARNING] Cannot read extended EXIF tags for DJI_0346.JPG: ‘str’ object has no attribute ‘den’
[WARNING] Cannot read extended EXIF tags for DJI_0349.JPG: ‘bytes’ object has no attribute ‘den’
[WARNING] Cannot read extended EXIF tags for DJI_0351.JPG: ‘bytes’ object has no attribute ‘den’
[WARNING] Cannot read extended EXIF tags for DJI_0377.JPG: ‘str’ object has no attribute ‘den’
best
Can you share those images? I wonder if there aren’t some EXIF tags DJI added that are causing the problem.
I’ll send them to you
