Hi, I am running nodeODM through docker on a linux-vm which is running on a server. The linux-vm have limited storage and i would like to store the projectdata/results in the servers main storage which I access through the “local network”. Thing is I am new to both linux, docker and ODM.
The NodeODM github readme shows this example of storing on a seperate drive:
docker run -p 3000:3000 -v /mnt/external_hd:/var/www/data opendronemap/nodeodm
Im thinking that maybe i could change the “/mnt/external_hd” to some location on my server storage. But i dont understand how i can specify the location to my server since when i access it through a terminal it says that i am in.
/run/user/1000/gvfs/smb-share:server=<Servername>, share=<Local file path in server filesystem>
Which from my small linux knowledge looks like program called “smb-share” that is accessing the server. So is this even possible?
Thanks for any help!
