Storage Question
Quick question regarding storage. Right now my setup is a mix of 2 servers.
Server 1 - Hosting WebODM and 3 instances of NodeODM
Server 2- Is hosting ClusterODM
The nodes are ran with docker on Ubuntu per the instructions. Cluster ODM as well. When projects are getting uploaded, where are they stored? I looked through the console log earlier and seems they were sent to var/www but I don’t have a www folder at least on any of the ubuntu distros. Are these going to the ESXI datastore file? If a file a project gets deleted from the dashboard, does it remove all the files off the server as well? Just trying if I’m going to have to manually go in and delete data off the servers.
Thanks,
They will be within the Docker container unless you use the --media-dir flag to redirect them elsewhere.
