I did a single processing with 170 images, now in the second project, I can’t move forward, the work is stopped at “Sending images to processing node”. Only 116 images and it doesn’t progress. What could be happening?
WebODM installer version (3.0.1)
Running out of disk space perhaps?
still have a lot of space
Apparently the problem has been resolved.
I found that the problem was in the hosts file (c:\windows\system32\drivers\etc\hosts). I followed the steps described in: https://support.microsoft.com/en-us/topic/how-to-reset-the-hosts-file-back-to-the-default-c2a43f9d-e176-c6f3-e4ef- 3500277a6dae and now the job is running. Strange that the first project I ran normally, the problem happened in the second project.
Thanks for this solution. I was having the same issue and it appears to have fixed it.
